    I have a Gate turret mill with Anilam Servos and amps with a retrofit CSMIO /IPA CNC controller (Anilam brain dead hence retrofit) and am using Mach3 currently with a Big Tex screen set as I need to be able to change tools on the fly. All is not entirely well with Tex is there a better alternative to Big Tex.
    Lives in Plymouth, United Kingdom. Last Activity: 19 Hours Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    Two popular choices are the "2010 screen set" from Gerry/ger21, and the machstdmill screen set from Calypso Ventures. I know people who use both very happily, although I personally use the standard Mach3 offering with some slight tweaks of my own. A google search will find both of the ones I've named. Can't help with whether or not they help with tool-changing - I've found the standard features of Mach3 sufficient but I'm not using a professional machine.
    Chaz's Avatar
    2010 from Ger. I'm using this now and I should have changed to it years ago.
  5. The Following User Says Thank You to Chaz For This Useful Post:
  6. #4
    I'm using Hoss's screenset, perfect for what I do, and lots of youtube videos on how to set it up/tweak it.
  7. #5
    Personally, Ger21's Mach2010 is the better of the commercial ones.
    The hoops you have to jump through with MachSTD to get it installed and the fact that it is not 100% compatible with the CSMIO killed that one for me years ago....and I dont even use CSMIO products hehe
    https://emvioeng.com
  8. The Following User Says Thank You to komatias For This Useful Post:
  9. I also use Ger21's Mach2010 screen-set, I personally find it to be the best one to use.
    "If first you don't succeed, redefine success"
  10. #7
    Is it feasible to load a couple of screen sets without inter-corruption, I have a suspicion that my Big Tex installation has been corrupted by a previous screen set e.g. M6 overrides the tool change position and reverts to a location I had set for a previous screen set?
  11. #8
    Quote Originally Posted by kirby43a View Post
    I don't think that changing a screenset will change other aspects of that profile. The macros are stored per-profile, i.e. typically per machine, so if you updated a macro in one profile, that change won't be seen in other profiles.
    However, there are a few odd things that can happen around M6 that aren't quite right if you are using a CSMIO-IP/M, and I wouldn't be surprised if it's not true for other CSMIO variants. For example, when I first started playing with tool height setting/resetting during an M6 tool change (i.e. between the calls to M6start and M6end), there were problems about losing X and Y position. The fix (in my case) was to "upgrade" to an earlier version of mach3. I'm currently using 3.043.028 which is not the latest version but can still be downloaded and installed. Remember to save any profile modifications in a custom machine profile and not mach3mill or any of the other out-of-the-box profiles or they will definitely be overwritten. The CSMIO compatibility thing is well-known and documented but you won't generally find it unless you go looking for it.
  12. #9
    Chaz's Avatar
    Quote Originally Posted by Mad Professor View Post
    Mmmm. I know this nick. Ex 3D printing world?
  13. The Following User Says Thank You to Chaz For This Useful Post:
