25-11-2017 #3
The extrusion has an 8mm slot, but I will be using M6 bolts for the 25mm Hiwin rails.
The inner extra gantry sides are basically 4x detachable right angle brackets (for front and rear of gantry) that bolt to both gantry and base. Just a little extra support. It's difficult to see because the renderer "fuses" everything as if it were a continuous flat. One way to avoid that is to put a tiny chamfer so it shows separation between pieces, but I haven't bothered with this or with covers and other finishing details.Last edited by Edward; 25-11-2017 at 05:17 PM.
BUILD LOG: Well here goes... Aluminium frame router design
By CharlieRam in forum DIY Router Build LogsReplies: 186Last Post: 11-05-2020, 12:39 PM -
BUILD LOG: Small rigid router - Design advise needed
By mitchejc in forum DIY Router Build LogsReplies: 120Last Post: 17-06-2015, 08:12 AM -
Small desktop mill/router for cutting <=6mm aluminium
By matt-b2 in forum Marketplace DiscussionReplies: 2Last Post: 08-12-2013, 01:04 AM -
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 21-10-2011, 04:50 PM -
Small Mill very early design stage
By leadinglights in forum Milling Machines, Builds & ConversionsReplies: 29Last Post: 15-06-2010, 01:05 AM
