    Hi guys,
    I would like an opinion on Z ballscrew 1605 1:1 vs 1610 with 1:2 reduction.
    I cant decide.
    Will a Z axis 1610 run down under its own weight when not under power?
    Setup:
    Fixed float.
    Pully/belt
    length 350mm
    A few other questions.
    Do i need more resolution then 0.025 mm on Z per full step?
    Do i need to aim for 0.01 mm per step for some reason i dont know yet?
    What is to be expected from a stepper in lets say 4 microstep setup... can a stepper hold position and or will it return to for example 1/4 step position after it is pushed out of position a little.. lets say 1/8 step.... Looks like it would but this is just my gut feeling.
    I think i am comfortable with 0.025mm full step resolution.
    (1610 reduced 1:2 stepper 1.8 degree)
    but unsure if micro stepping adds anything useful for resolution.
    I know resolution is not the same as repeatability.
    I have been looking around for these info's but did not find a satisfactory answer to this.
    Grtz Bert.
    I was interested and waiting for replies to this question............surprised there are no comments yet
  3. The Following User Says Thank You to MartinS For This Useful Post:
    Lives in Plymouth, United Kingdom. Last Activity: 22 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Not a lot of theory here, but this works for me...
    I use 1605, 1-1 belt drive from stepper. Z feed rate is generally lower than X and Y, so you do not need 10mm lead ballscrews. I have never had any problems with downward creep of Z, even with power off, and that's with a big chunk (500x200x20) of tooling plate for the spindle platform and a 2.2KW spindle. I use 8x microstepping. This is not so much for resolution (I have a theoretical 0.003mm step increment) but for motor smoothness. Something around 8x seems like a good compromise between smooth running (fewer microsteps runs more roughly) and loss of torque (with too fine microstepping). However, testing with my touchplate, I have seen +-1 microstep (i.e. +-0.0003mm) repeatability. I doubt if the machine is that accurate when cutting, but even with intricate 3D machining, I have not seen any problems.
  5. The Following User Says Thank You to Neale For This Useful Post:
  6. #4
    Ok this answers the question... i will change my bomlist..
    1605 for z 1:1 pullys.
    I have zero hands on experience so...
    Grtz Bert.
  7. #5
    For a Z I would belt drive and reduce to 2:1. As Z motions are not always as long as the X and Y you can live with a slower speed.
    The 2:1 will also ensure you do not drop as easily when the motors are off. It may not be a concern of course if you are using bog standard screws.
    (I know on my little CNC conversion kits, because I am using ground screws, you can easily backdrive them. Then again the head weighs around 30kg there)
    https://emvioeng.com
  8. The Following User Says Thank You to komatias For This Useful Post:
  9. #6
    I reckon that my moving Z components weigh around 15kg and that seems OK with 1605 and 1-1 pulleys. However, one of the great things about belt drive is that you can always change ratios if you need to without too much work.
  10. The Following User Says Thank You to Neale For This Useful Post:
  11. #7
    I was also interested ;)
    I got 1610 delivered from China but ordered 1605.. solved this with pulleys 2:1 ratio.
    My z axis plate is 300x160x15 in steel and 2.2kw spindle.
    Just got a belt mounted on the pulleys and the motor supports it from dropping without power.
    How it's working under power remains to be seen :D
  12. The Following User Says Thank You to Nr1madman For This Useful Post:
  13. #8
    Ok guys thanx for the infos... i send a final rfq to Fred...
    Maybe i will have parts before new year.
    Grtz. Bert.
  1. Ball screw advice
    By Darren in forum Lead Screws, Nuts & Supports
    Last Post: 10-04-2016, 10:52 PM
  2. Ball screw
    By luke11cnc in forum Lead Screws, Nuts & Supports
    Last Post: 20-10-2011, 01:28 PM
  3. WANTED: 12mm ball screw & nut
    By phill05 in forum Items Wanted
    Last Post: 22-06-2010, 09:26 PM
  4. Stationary Ball Screw
    By Wobblybootie in forum Lead Screws, Nuts & Supports
    Last Post: 29-12-2009, 01:12 PM
  5. Twin ball screw drive on X - configuration question
    By HiltonSteve in forum Gantry/Router Machines & Building
    Last Post: 20-05-2009, 11:13 PM
