Thread: Zaxis Ball screw question
25-11-2017 #1
Hi guys,
I would like an opinion on Z ballscrew 1605 1:1 vs 1610 with 1:2 reduction.
I cant decide.
Will a Z axis 1610 run down under its own weight when not under power?
Setup:
Fixed float.
Pully/belt
length 350mm
A few other questions.
Do i need more resolution then 0.025 mm on Z per full step?
Do i need to aim for 0.01 mm per step for some reason i dont know yet?
What is to be expected from a stepper in lets say 4 microstep setup... can a stepper hold position and or will it return to for example 1/4 step position after it is pushed out of position a little.. lets say 1/8 step.... Looks like it would but this is just my gut feeling.
I think i am comfortable with 0.025mm full step resolution.
(1610 reduced 1:2 stepper 1.8 degree)
but unsure if micro stepping adds anything useful for resolution.
I know resolution is not the same as repeatability.
I have been looking around for these info's but did not find a satisfactory answer to this.
Grtz Bert.
28-11-2017 #2
I was interested and waiting for replies to this question............surprised there are no comments yet
The Following User Says Thank You to MartinS For This Useful Post:
28-11-2017 #3
Not a lot of theory here, but this works for me...
I use 1605, 1-1 belt drive from stepper. Z feed rate is generally lower than X and Y, so you do not need 10mm lead ballscrews. I have never had any problems with downward creep of Z, even with power off, and that's with a big chunk (500x200x20) of tooling plate for the spindle platform and a 2.2KW spindle. I use 8x microstepping. This is not so much for resolution (I have a theoretical 0.003mm step increment) but for motor smoothness. Something around 8x seems like a good compromise between smooth running (fewer microsteps runs more roughly) and loss of torque (with too fine microstepping). However, testing with my touchplate, I have seen +-1 microstep (i.e. +-0.0003mm) repeatability. I doubt if the machine is that accurate when cutting, but even with intricate 3D machining, I have not seen any problems.
28-11-2017 #4
I was also interested ;)
I got 1610 delivered from China but ordered 1605.. solved this with pulleys 2:1 ratio.
My z axis plate is 300x160x15 in steel and 2.2kw spindle.
Just got a belt mounted on the pulleys and the motor supports it from dropping without power.
How it's working under power remains to be seen :D
The Following User Says Thank You to Nr1madman For This Useful Post:
29-11-2017 #5
29-11-2017 #6
For a Z I would belt drive and reduce to 2:1. As Z motions are not always as long as the X and Y you can live with a slower speed.
The 2:1 will also ensure you do not drop as easily when the motors are off. It may not be a concern of course if you are using bog standard screws.
(I know on my little CNC conversion kits, because I am using ground screws, you can easily backdrive them. Then again the head weighs around 30kg there)https://emvioeng.com
The Following User Says Thank You to komatias For This Useful Post:
29-11-2017 #7
I reckon that my moving Z components weigh around 15kg and that seems OK with 1605 and 1-1 pulleys. However, one of the great things about belt drive is that you can always change ratios if you need to without too much work.
29-11-2017 #8
My Z is also 1:1 with pulleys on 1605 and works fine
29-11-2017 #9
Ok guys thanx for the infos... i send a final rfq to Fred...
Maybe i will have parts before new year.
Grtz. Bert.
Ball screw advice
By Darren in forum Lead Screws, Nuts & SupportsReplies: 7Last Post: 10-04-2016, 10:52 PM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
WANTED: 12mm ball screw & nut
By phill05 in forum Items WantedReplies: 8Last Post: 22-06-2010, 09:26 PM -
Stationary Ball Screw
By Wobblybootie in forum Lead Screws, Nuts & SupportsReplies: 14Last Post: 29-12-2009, 01:12 PM -
Twin ball screw drive on X - configuration question
By HiltonSteve in forum Gantry/Router Machines & BuildingReplies: 13Last Post: 20-05-2009, 11:13 PM
