Thread: Zaxis Ball screw question
29-11-2017 #2
For a Z I would belt drive and reduce to 2:1. As Z motions are not always as long as the X and Y you can live with a slower speed.
The 2:1 will also ensure you do not drop as easily when the motors are off. It may not be a concern of course if you are using bog standard screws.
(I know on my little CNC conversion kits, because I am using ground screws, you can easily backdrive them. Then again the head weighs around 30kg there)https://emvioeng.com
The Following User Says Thank You to komatias For This Useful Post:
29-11-2017 #3
I reckon that my moving Z components weigh around 15kg and that seems OK with 1605 and 1-1 pulleys. However, one of the great things about belt drive is that you can always change ratios if you need to without too much work.
29-11-2017 #4
My Z is also 1:1 with pulleys on 1605 and works fine
Ball screw advice
By Darren in forum Lead Screws, Nuts & SupportsReplies: 7Last Post: 10-04-2016, 10:52 PM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
WANTED: 12mm ball screw & nut
By phill05 in forum Items WantedReplies: 8Last Post: 22-06-2010, 09:26 PM -
Stationary Ball Screw
By Wobblybootie in forum Lead Screws, Nuts & SupportsReplies: 14Last Post: 29-12-2009, 01:12 PM -
Twin ball screw drive on X - configuration question
By HiltonSteve in forum Gantry/Router Machines & BuildingReplies: 13Last Post: 20-05-2009, 11:13 PM
