Thread: Profile Circle on 3040
29-11-2017 #11
29-11-2017 #12I am sorry you feel like that but I suggest you re read this thread from the beginning and look back at your answers carefully and you will see that you have not given any clear reports back.I'm pretty new to cnc and i posted on here for help not criticism.
Did you run Doddy's code !! if so what is the result?..Clive
29-11-2017 #13
29-11-2017 #14
Did you zero your Z on the top of the part? You can see in his code:
G0 X0.0 Y0.0
G0 Z1.0
G1 F300.0 Z-0.4
G1 F800.0 X40.0
G1 Y40.0
G1 X0.0
That the Z will move to 1mm above the part and then sets the feed rate to 300mm/min and drops the Z to -0.4mm below the top of the part.
What do you mean by (just hovers) ie does it stay still or does it follow the intended path?..Clive
29-11-2017 #15
29-11-2017 #16Or the bed is going down. Have you levelled the bed and skimmed the top off?Yes I zeroed the top.
The z seems to move up the further it gets into the job...Clive
29-11-2017 #17
Hi, if you go to my blog it gives all the mach3 settings. It sounds like some of the settings are ok and some aren’t, so just spend a bit of time going through them. If you’re still unsure pm me and I’ll go through them with you
Kev
29-11-2017 #18
29-11-2017 #19
Are you just doing the settings on the motor settings page ?
29-11-2017 #20
Trying to mill a circle, not going to plan, and other issues.
By Crazy L in forum General DiscussionReplies: 7Last Post: 14-09-2017, 03:50 PM -
G Code For Drilling Circle
By dakes55 in forum Programmers CornerReplies: 0Last Post: 07-10-2016, 08:02 PM -
control signals to draw a circle
By lakmalp in forum Machine Control SoftwareReplies: 3Last Post: 16-06-2013, 05:52 PM -
circle cutting mach 3 problems help please
By millmateuk in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 13-06-2013, 07:04 AM -
Cutting out a circle
By Martin Paul in forum Machine DiscussionReplies: 2Last Post: 19-04-2011, 12:58 AM
