Thread: Profile Circle on 3040
...or...
...the PCB is not fixed to the table. - Are you using double sided tape over the whole surface of the PCB?
...the PCB is not flat enough. - Measured over the whole area with a caliper?
...the PCB is not even in thickness. - Checked for variations with a caliper?
...the table is not levelled.
...the X is not levelled to the table surface and is tilting the Z.
PCB is not the optimal for this sort of tests but many things can be wrong. Work with the G-code given to you, once you can mill a square you can move on to making other things, but don't jump from one to the other type of code. Personally I think you have alignment issues somewhere. You have to align everything mechanically as good as possible, measure every angle BEFORE surfacing the table. The surfacing is the last moment, when everything else is as good as it can be.
When making PCB it is important that you fix the PCB over the whole area to eliminate warping or bending. At least if it is a large piece and if the PCB is low quality.
Trying to mill a circle, not going to plan, and other issues.
By Crazy L in forum General DiscussionReplies: 7Last Post: 14-09-2017, 03:50 PM -
G Code For Drilling Circle
By dakes55 in forum Programmers CornerReplies: 0Last Post: 07-10-2016, 08:02 PM -
control signals to draw a circle
By lakmalp in forum Machine Control SoftwareReplies: 3Last Post: 16-06-2013, 05:52 PM -
circle cutting mach 3 problems help please
By millmateuk in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 13-06-2013, 07:04 AM -
Cutting out a circle
By Martin Paul in forum Machine DiscussionReplies: 2Last Post: 19-04-2011, 12:58 AM
