    Yes XYZ is channel 0-1-2 and so on.
    I have my probe working well now - the secret is to allow some time in the macro so pad it with "Sleep(100)" lines after a DRO update etc also it ONLY works with soft limits turned off - i just made the macro turn limits off then on when the move was made.
    Its going well now.
    Lives in Plymouth, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Yes, that's a bit of a gotcha - that "sleep" after a DRO update is absolutely vital, as is the "while moving" loop so you wait for the machine to reach target position before carrying out the next action. However, my version works fine with soft limits, so not sure what's going on there.
    Yes, its only a 0.1s wait and it needs going after every DRO update, i also padded it after every DRO read, plus the totally essential while-ismoving loop on ANY call that creates movement of an axis.
    Doing this likely added 5s to the macro run time but thats no bother if its what it takes to make it work 100%
    The soft limits thing i'm going to play with again - it seems very version dependant so now I have the timings sorted, ill try leaving it on and see what occurs. CSLABS said they had never heard of it BUT they always run v022 so that may be why.
  1. csmio/ip-m z probe
    By charlieuk in forum CS-Lab (CSMIO)
    Last Post: 16-09-2017, 09:49 AM
  2. mach3 csmio ips errors
    By Web Goblin in forum Artsoft Mach (3 & 4)
    Last Post: 07-01-2017, 10:47 PM
  3. Mach3 oem buttons with CSMIO-IP/S
    Last Post: 07-11-2016, 07:14 AM
  4. CSMIO-M Tool Probe Connection - +24v to earth
    By Noplace in forum CS-Lab (CSMIO)
    Last Post: 10-04-2016, 09:17 PM
  5. Weird problem - stepped/staged deceleration on Huanyang 2.2kw Spindle
    By glynster in forum Spindles & Drive Motors
    Last Post: 25-01-2016, 01:39 PM
