06-12-2017 #15
I agree with m_c about which wires to remove, however it may be easier just to pull the connections from C1 and SP at the brake board.(insulate them after diconnecting)
I don't know about the switch enigma but as a starting point you should always check contacts with the wires disconnected to prevent feedback.
If it's okay in the saw position I suggest getting the machine running like that for a start.
Operation of the brake looks like this to me.
If there is voltage or has been voltage at terminal SP (even briefly) and there is a circuit from C1 through the motor winding back to L3 (i.e. contactor has just been de-energised) then brake.
If there is voltage at terminal SP (even briefly) and there is no circuit from C1 through the motor winding back to L3 (i.e. contactor energised) then do not brake.
If there is no voltage at terminal SP (or a brake operation has just completed) and there is a circuit from C1 through the motor winding back to L3 then do not brake.
This also explains why the brake will activate if 'start' is pressed while an e/stop is activated. Start button contact 23/24 apply voltage to SP briefly when pressed but the contactor is de-energised.Last edited by EddyCurrent; 06-12-2017 at 10:35 AM.
Finding spindle suppliers in UK
By freddi in forum Spindles & Drive MotorsReplies: 1Last Post: 07-02-2017, 08:16 PM -
combination machine.
By Popp Ann in forum 3D Printing MachinesReplies: 14Last Post: 23-02-2016, 10:35 AM -
eBay: Cutler and Hammer (vice?) foot pedal
By jamesgates1000 in forum Items On eBay UKReplies: 0Last Post: 20-10-2015, 07:33 AM -
Best CNC Software Combination
By Ricardoco in forum CAD & CAM SoftwareReplies: 12Last Post: 29-08-2011, 12:57 AM -
Edge Finding For Newbies
By M250cnc in forum CAD & CAM SoftwareReplies: 14Last Post: 01-03-2011, 10:55 AM
