Name:	MC Electrical Drawing 001 (2) (1024x745).jpg
Drawing any better Nick?
Translation from German:
1 Home
2 Switching Unit
3 On Off Switch
4 Overload Protection
5 Contactor
6 Auxiliary Contactor
7 Braking Circuit
8 Transformer
9 Fuse
10 Selector Switch
11 Limit Switch
12 Emergency Stop
13 Emergency Stop
14 Motor – Saw
15 Motor – Spindle Moulder
16 Motor – Planer
17 Plug
18 Limit Switch
19 Limit Switch
20 Terminal Strip
Yes the motors are 3 phase run from a Transwave inverter.
So disconnect wire R7 from the contactor to eliminate the Braking circuit?
Does it trip when you start a motor or when you press a stop button ?
It trips or won't start when you press the start button. Contacts flash, chatter. But it does run on all three motors once it decides to hold the contacts in.
But I don't think the contactor will last long if I keep using it like this.
Thank you for your suggestions I will have another look at it tomorrow.
