The rotary switch.
1 - L1
3 - L2
17 - L3
10 - Saw Motor U1
12 - Saw Motor V1
20 - Saw Motor W1
6 - Moulder Motor U1
4 - Moulder Motor V1
18 - Moulder Motor W1
14 - Planer Motor U1
16 - Planer Motor V1
22 - Planer Motor W1
23 - 230v control
24 - 230v control
This is how I would expect the switching to be.
in Saw position, L1,L2,L3 will be connected to the saw motor only
in Moulder Fwd position, L1,L2,L3 will be connected to the moulder motor only
in Moulder Rev position, L1,L2,L3 will be connected to the moulder motor only, but two phases will have been swapped over
in Planer position, L1,L2,L3 will be connected to the planer motor only
in all positions terminals 23 and 24 will be connected in order to complete the 230v control circuit.
It probably goes through the switch because the contact between 23 and 24 will go open circuit between positions
thus dropping the contactor out if the switch is moved while a motor is running.
That being the case it should be fairly easy, though laborious, to test it.
1. Mark up the wires securely, you don't want a label dropping off, masking tape works okay.
2. Also take however many photos it needs to be sure all the wires will go back in the same position (there may be links from one terminal to another, leave them in place)
3. remove the wires and test the switch arrangement using terminals 1,3,17 as the reference terminals, make good notes with pen and paper.
For each position of the switch make a note of;
a) which terminals are connected to terminal 1
b) which terminals are connected to terminal 3
c) which terminals are connected to terminal 17
d) state of terminals 23 to 24
4. do the results match what we think it should be ? (using the information above)
Sorry if my instructions seem childish, I've learned the hard way (many call outs through night) that leaving easy to follow unambiguous instructions is the best way to achieve success (and let me get a nights sleep, although all that is past me now)Last edited by EddyCurrent; 08-12-2017 at 09:33 AM.
08-12-2017 #2
Given the fault seemed to affect all functions, my money would be a voltage drop in something common to all functions.
I certainly wouldn't be unwiring such a complex switch just to test how it works, when you can get far more accurate readings by testing it under load, by measuring voltages...
Plus, the fault could quite easily be with some of the other safety switches in the control circuit.
The only thing I'd do now everything is working, is double check all the connections at the switches, and work them a few times to work the contacts. If the switches haven't been operated for a while, the contacts could oxidise causing a voltage drop, and working them a couple times can be enough to get them working again for a while.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
08-12-2017 #3
The switch information is there in case it's required, I had some time to spare last night.
Finding spindle suppliers in UK
By freddi in forum Spindles & Drive MotorsReplies: 1Last Post: 07-02-2017, 08:16 PM -
combination machine.
By Popp Ann in forum 3D Printing MachinesReplies: 14Last Post: 23-02-2016, 10:35 AM -
eBay: Cutler and Hammer (vice?) foot pedal
By jamesgates1000 in forum Items On eBay UKReplies: 0Last Post: 20-10-2015, 07:33 AM -
Best CNC Software Combination
By Ricardoco in forum CAD & CAM SoftwareReplies: 12Last Post: 29-08-2011, 12:57 AM -
Edge Finding For Newbies
By M250cnc in forum CAD & CAM SoftwareReplies: 14Last Post: 01-03-2011, 10:55 AM
