Thread: parts just for wood and plastic
It all depends on what kind of accuracy you are aiming for.
Some people think/say that rails mounted directly on extrusion is a sure failure.
For some it's just fine and easier to mount with t-nuts instead of drilling and tapping.
If you are looking at something like +-0.1mm in wood then it would probably suffice!
03-12-2017 #2
In my experience, cutting acrylic needs a stiff router. I was cutting 20mm extruded acrylic in 5mm passes with a 6mm endmill and my 280kg table was vibrating a lot... :) If you are going to cut in 0.5mm passes there will be no problem, only time wasted.
The steel route is cheaper, faster and sturdier than aluminium if you are cutting, welding, drilling, tapping by yourself and of course epoxy levellling the rail beds.
RFQ: Very small plastic parts - mid quantities
By Ellis in forum Projects, Jobs & RequestsReplies: 0Last Post: 23-04-2015, 11:26 AM -
RFQ: Wood CNC routing service (wood Letters)
By coujin in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-02-2015, 03:35 PM -
RFQ: Plastic parts. 3 axis machined.
By jimbo_cnc in forum Projects, Jobs & RequestsReplies: 0Last Post: 11-07-2014, 04:38 PM -
BUILD LOG: Design stage of 4030(ish) for wood and plastic
By andy586 in forum DIY Router Build LogsReplies: 4Last Post: 14-11-2013, 10:07 PM -
RFQ: Small parts from FR4 plastic - help!
By James in forum Projects, Jobs & RequestsReplies: 1Last Post: 12-06-2012, 04:02 PM
