Page 7 of 21 FirstFirst ... 5678917 ... LastLast
  1. Quote Originally Posted by reefy86 View Post
    anything wrong with this frame and is the diagonal supports ott? i will be adding adjustable feet on aswell
    cheers
    Attachment 23334
    Attachment 23335
    You forgot diagonals when looking in the plan view, see here what I mean; http://www.mycncuk.com/threads/6565-...2425#post52425
  2. #62
    Thank you cropwell i will look more into this.
    cheers
  3. #63
    You forgot diagonals when looking in the plan vew, see here what I mean; http://www.mycncuk.com/threads/6565-...2425#post52425
    Thanks eddy ill add these in :)
  4. #64
    if only you could get the steel this clean lol, anyways i know i did this all before but ive done a few tweaks but i am a little concerned with the gantry side plates being so wide and because the aluminium gantry beam is pushed to the back it leaves a large space on the flange plates. this is because i was reading about not having the z axis over hanging and to have the gantry side plates in front of the z axis.
    I have gone with 100x100x5mm all round for the frame
    all plates are 20mm thick aluminium
    linear rails 25mm
    ballscrews r2010 driven on both sides with nema 23's 4nm and a rotating ball nut due to long 3000mm ballscrews
    still thinking for the rest but whats your thoughts?
  5. #65
    is £400 the going rate for 3 meter ballscrews r2010?
  6. #66
    noob question here with it being the first time tapping a hole my self if the linear rails holes are 4.5mm what would the tap size be to the aluminium plate its attaching to?
  7. #67
    If the holes really are 4.5 mm diameter in the rail they are expecting you to use M4 cap head bolts to allow some adjustment. You need a 3.3 mm drill for the pilot drill, followed by an M4 x 0.7 pitch tap (coarse thread).
    But I would expect a 25 mm rail to use M6 cap heads? If so these would need a 5mm pilot hole then an M6 x 1 pitch tap (coarse thread).
  8. What's with the parquet bed?!
  9. #69
    I didn't think they would be that small, an M4 screw is pretty weedy, there must be lots of them. As a good rule of thumb tap drill size is screw diameter - thread pitch, so for M4 normally 0.5mm pitch would mean a 3.5 mm drill.
  10. #70
    its 4.5mm on the 15mm rails for the z axis.
    thanks again
  2. BUILD LOG: All steel, no welding, 2000x1300x250mm
    By eurikain in forum DIY Router Build Logs
    Last Post: 28-06-2017, 12:51 PM
  3. BUILD LOG: Small workshop CNC router, steel base, planning on ATC
    By spresv in forum DIY Router Build Logs
    Last Post: 07-02-2017, 04:28 PM
  4. Steel base
    By D-man in forum Items For Sale
    Last Post: 09-05-2016, 01:22 PM
  5. Redesign...Steel is now Extrusion
    By FlyHighRC in forum Gantry/Router Machines & Building
    Last Post: 30-10-2015, 10:09 PM
