10-12-2017 #71
10-12-2017 #72
10-12-2017 #73
10-12-2017 #74
10-12-2017 #75
10-12-2017 #76
OK, then either:
pilot 3.3 mm for an M4 x 0.7 (coarse thread)
pilot 3.5 mm for an M4 x 0.5 (fine thread)
In general I would use coarse thread, especially into aluminium. Get a countersink to clean up the hole and get snug fit of the rail onto the plate - snail countersinks are great.
Also, thread lock (the type you can undo) the screw into the hole as the spindle vibration can undo them.
10-12-2017 #77
thanks mate ill take a look at those
10-12-2017 #78
is this what you was talking about for thread lock or is it the stuff in a bottle?
http://www.longlok.com/s.nl/it.A/id.42699/.fLast edited by reefy86; 10-12-2017 at 04:08 PM.
10-12-2017 #79
Before he goes and drills the wrong size tapping hole. Metric coarse is M4 x.7 which is the standard metric range. So you need a 3.3 tapping drill.
Sorry, posts crossed having a crappy slow internet today and refresh problems.Last edited by spluppit; 10-12-2017 at 04:13 PM.
10-12-2017 #80
Inside the box section I used a length of 6mm flat strap to increase the thread length for the rails; http://www.mycncuk.com/threads/6565-...4981#post54981
If you are using the epoxy levelling method, don't forget to allow some thread length for that.Last edited by EddyCurrent; 10-12-2017 at 04:35 PM.
BUILD LOG: All steel, no welding, 2000x1300x250mm
By eurikain in forum DIY Router Build LogsReplies: 55Last Post: 28-06-2017, 12:51 PM -
BUILD LOG: Small workshop CNC router, steel base, planning on ATC
By spresv in forum DIY Router Build LogsReplies: 24Last Post: 07-02-2017, 04:28 PM -
Steel base
By D-man in forum Items For SaleReplies: 4Last Post: 09-05-2016, 01:22 PM -
Redesign...Steel is now Extrusion
By FlyHighRC in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 30-10-2015, 10:09 PM
. As a good rule of thumb tap drill size is screw diameter - thread pitch, so for M4 normally 0.5mm pitch would mean a 3.5 mm drill.
