Page 8 of 21 FirstFirst ... 67891018 ... LastLast
  1. #71
    Quote Originally Posted by JoeHarris View Post
    What's with the parquet bed?!
    using keyshot as a quick render and was looking in the wood library and thought this looked quirky lol
  2. #72
    If the holes really are 4.5 mm diameter in the rail they are expecting you to use M4 cap head bolts to allow some adjustment. You need a 3.3 mm drill for the pilot drill, followed by an M4 x 0.7 pitch tap (coarse thread).
    But I would expect a 25 mm rail to use M6 cap heads? If so these would need a 5mm pilot hole then an M6 x 1 pitch tap (coarse thread).
    Why a coarse thread ?
  3. #73
    I didn't think they would be that small, an M4 screw is pretty weedy, there must be lots of them. As a good rule of thumb tap drill size is screw diameter - thread pitch, so for M4 normally 0.5mm pitch would mean a 3.5 mm drill.
    Helpful cheers for that
  4. Quote Originally Posted by reefy86 View Post
    Yes it looks cool! Not such a good idea in reality?! Wish I could afford keyshot, looks amazing. Btw you probably won't need two mounts for the spindle and it will make it harder to align.
  5. #75
    you can get better results using vray in 3ds max but i can't be bothered to spend hours making materials and setting render up lol. thanks for the heads up on the mount i will remove one of them
  6. #76
    OK, then either:
    pilot 3.3 mm for an M4 x 0.7 (coarse thread)
    pilot 3.5 mm for an M4 x 0.5 (fine thread)
    In general I would use coarse thread, especially into aluminium. Get a countersink to clean up the hole and get snug fit of the rail onto the plate - snail countersinks are great.
    Also, thread lock (the type you can undo) the screw into the hole as the spindle vibration can undo them.
  7. #77
    thanks mate ill take a look at those
  8. #78
    OK, then either:
    is this what you was talking about for thread lock or is it the stuff in a bottle?
    http://www.longlok.com/s.nl/it.A/id.42699/.f
  9. #79
    Before he goes and drills the wrong size tapping hole. Metric coarse is M4 x.7 which is the standard metric range. So you need a 3.3 tapping drill.
    Sorry, posts crossed having a crappy slow internet today and refresh problems.
  10. Inside the box section I used a length of 6mm flat strap to increase the thread length for the rails; http://www.mycncuk.com/threads/6565-...4981#post54981
    If you are using the epoxy levelling method, don't forget to allow some thread length for that.
  2. BUILD LOG: All steel, no welding, 2000x1300x250mm
    By eurikain in forum DIY Router Build Logs
    Last Post: 28-06-2017, 12:51 PM
  3. BUILD LOG: Small workshop CNC router, steel base, planning on ATC
    By spresv in forum DIY Router Build Logs
    Last Post: 07-02-2017, 04:28 PM
  4. Steel base
    By D-man in forum Items For Sale
    Last Post: 09-05-2016, 01:22 PM
  5. Redesign...Steel is now Extrusion
    By FlyHighRC in forum Gantry/Router Machines & Building
    Last Post: 30-10-2015, 10:09 PM
