Page 18 of 21 FirstFirst ... 81617181920 ... LastLast
  1. #171
    most of the 3d work will be on mdf
  2. #172
    Lives in Plymouth, United Kingdom. Last Activity: 4 Hours Ago Has a total post count of 1,747. Received thanks 298 times, giving thanks to others 11 times.
    Any chance you can use layering in your CAM setup to cut the piece in layers with registration pins for cutting and reassembly? I know it depends on what you are making, but just in case this is for something like MDF moulds, it might do the job.
  3. #173
    It was a thought but joining those pieces together and making it look seamless on some pieces maybe tricky.
  4. #174
    how much room play do you leave when drilling and tapping? for example i am using 20mm linear rails on the z axis and the screw clearance is 6mm so i would need to use smaller bolts then 6mm to make room for alignment.
  5. #175
    Quote Originally Posted by reefy86 View Post
    I made a huge error when drilling/tapping my first plate. Went with m6 as the holes were 6mm and chinese drawing said m6 holes.
    Turns out that m6 boltheads couldnt fit the countersink in the rails :D
    So use m5 bolts, 4.2mm drill..
    That gives you 1mm adjustment.
    Done correctly thats plenty ;)
  6. #176
    Thanks i had m5 in mind but wanted to double check :)
  7. #177
    I used M5 as well - works fine and although you don't have a lot of adjustment range, there should be enough if you are careful. I made up a steel drill guide (a short length of steel bar with a 4.3mm hole through the middle) that had a reduced diameter one end that fitted the counterbores in the rail so it centred the drill accurately. You can then use a similar guide with a 5.1mm hole to guide the tap so that it goes in square.
  8. #178
    M5 too here.
    The first of a set of 20mm hiwin X axis rails takes a lot of time to line up to what ever straight reference.
    I checked 100 times before drilling the first holes.
    After squaring up the gantry to the first rail, the second rail (X) wend a lot faster using the gantry as a guide for the second rail relative distance.
    I clamped down using 3 clamps before pre drilling 3 holes over 1830 mm span, ends and middle, with a 5.9mm drill, to remove epoxy and centre drilling a centre hole for 4.2 mm drill.
    I have a well balanced, old :-) battery drill.
    Its easy to keep vertical 90 degrees to the surface and used no other tools.
    I used the 6mm hole from the rail for a guide icm with the 5.9 epoxy removal / pre centre drill and drilled 4.2 and tapped all m5 free hand with the battery drill.
    Bought 2 machine taps m5 and 5 4.2 drills from toolstation (volkel) did about 100 holes in 4mm steel with 1 drill 4.2mm (ground hss) and 1 tap and still going strong.
    Just use oil on drill and tap, and vacuum clean all holes before tapping.
    I have had no problems with off centre holes or problems tapping the treads.
    After tapping there is some wiggle room but not a lot about 0.5mm ...
    After torqueing down the m5 i have had no binding trouble in the carriages.
    Hope this helps.
    Grtz Bert
  9. #179
    Thanks guys, just would like to ask a question that i can't seem to find the answer to on the forum But has anyone ran a machine for multiple years using epoxy resin without it weakening over time? also what methods do you do to get top and bottom rails lined up to exact same position?
    Got my keys today for my workshop so will be cracking on soon :)
  10. #180
    Hi reefy86,
    I would like an answer to the epoxy question to :-)
    For Y rail alignment?
    I used 2 extruded profiles across the x rails in front of an behind the gantry.
    And 2 across on top of them, parallel to the x rails under the gantry.
    Now you have 2 flat references to put 2 machinist squares on. in a horizontal/ upright position on both sides of the gantry.
    In the same X rail level plain.
    The bottom of my gantry is half raised 12+ cm over the X rails.
    I moved the rail so the carriages are just over the edge of the beam so it is close as possible to the Z axis side so the machinist square just touches them and not the gantry box section.
    The rail is on the edge of useable flat of the epoxy.
    Hope this helps.
    Some left over extrusion 8040 goes a long way for alignment purposes.
    I did check them for resonable straightness before using them this way.
    You need square and flat references all through the build, i did under estimate this.
    If not for epoxy this would never have worked out for me.
    Grtz Bert
  2. BUILD LOG: All steel, no welding, 2000x1300x250mm
    By eurikain in forum DIY Router Build Logs
    Last Post: 28-06-2017, 12:51 PM
  3. BUILD LOG: Small workshop CNC router, steel base, planning on ATC
    By spresv in forum DIY Router Build Logs
    Last Post: 07-02-2017, 04:28 PM
  4. Steel base
    By D-man in forum Items For Sale
    Last Post: 09-05-2016, 01:22 PM
  5. Redesign...Steel is now Extrusion
    By FlyHighRC in forum Gantry/Router Machines & Building
    Last Post: 30-10-2015, 10:09 PM
