08-12-2017 #51
Thanks guy's. i already had in mind to get plenty of clamps, a large spirit level and large straight square edges so i'm glad i was on the right track.
08-12-2017 #52
Reefy, have you tried Nottingham Steel at Colwick, they will cut to size and they are probably cheaper !
Weld UK at Pinxton have got some heavy duty clamps at £60. I called in in person for one and asked how much they could do two for cash and it was a good discount !
https://www.welduk.com/product/sip-0...rs-angle-clampLast edited by cropwell; 08-12-2017 at 01:20 AM.
08-12-2017 #53
No not tried them mate, i will give them a call tomorrow so thanks for that
08-12-2017 #54
Do not try to make all like 2000mm, for example. make it 2003mm but parallel and square. Hence you don't need the pieces to be super precisely cut. You will definitely need a box of washers though, to fill the cracks. Remember that your final epoxy cast below rails will be 40mm wide, and rails are 20mm wide. The ???what was the name of it, the epoxy that lifted to the sides due to attraction will be 3-4mm each side, so basically you will be able to position the rails within that margin of the rest 10mm. hence do the gantry when you have finished and measured your final base frame, not at the same time.
And as you have been told, not bigger stitches than 2 inch at a time and place, and no higher overall temp of the beam than 60C. When you reach that temp, leave to cool before continue.
You will be tempted to hurry, but take your time and do it properly, you are not welding a typical welders job. I would go as far as to say that i will not trust a normal welder to do that job, as the moment i turn my back he will make 2 meter stitch
PS. best is to use hard stop ruler or a contraption to make all exact same distanceLast edited by Boyan Silyavski; 08-12-2017 at 01:44 AM.
08-12-2017 #55
08-12-2017 #56
08-12-2017 #57
08-12-2017 #58
thank you
08-12-2017 #59
just ringing up some local places but before i do how much gas do you think ill be using? i have no idea if 10 litres or a thousand litres and i defiantly do not want to run out halfway through lol.
what do you think of this welder
https://www.ebay.co.uk/itm/MIG-WELDE...MAAOSwEzxYR~E6Last edited by reefy86; 08-12-2017 at 04:47 PM.
08-12-2017 #60
It looks OK, but just be aware that it should not run off a 13A socket.
As far as gas is concerned, get a cylinder, the disposables will cost a fortune and only last about 20 minutes (if you are lucky). There are two options Rent or Buy, Renting will cost you more and if you buy you can go pub gas or argon welding mix. Pub gas (Carbon dioxide) is cheaper but the proper weld mix gives better results https://www.hobbyweld.co.uk is a good place to look. Don't forget you will also need a regulator and flow meter.
I would also recommend an auto-darkening mask.
BUILD LOG: All steel, no welding, 2000x1300x250mm
By eurikain in forum DIY Router Build LogsReplies: 55Last Post: 28-06-2017, 12:51 PM -
BUILD LOG: Small workshop CNC router, steel base, planning on ATC
By spresv in forum DIY Router Build LogsReplies: 24Last Post: 07-02-2017, 04:28 PM -
Steel base
By D-man in forum Items For SaleReplies: 4Last Post: 09-05-2016, 01:22 PM -
Redesign...Steel is now Extrusion
By FlyHighRC in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 30-10-2015, 10:09 PM
