08-12-2017 #61
You forgot diagonals when looking in the plan view, see here what I mean; http://www.mycncuk.com/threads/6565-...2425#post52425
08-12-2017 #62
Thank you cropwell i will look more into this.
cheers
08-12-2017 #63
09-12-2017 #64
if only you could get the steel this clean lol, anyways i know i did this all before but ive done a few tweaks but i am a little concerned with the gantry side plates being so wide and because the aluminium gantry beam is pushed to the back it leaves a large space on the flange plates. this is because i was reading about not having the z axis over hanging and to have the gantry side plates in front of the z axis.
I have gone with 100x100x5mm all round for the frame
all plates are 20mm thick aluminium
linear rails 25mm
ballscrews r2010 driven on both sides with nema 23's 4nm and a rotating ball nut due to long 3000mm ballscrews
still thinking for the rest but whats your thoughts?
09-12-2017 #65
is £400 the going rate for 3 meter ballscrews r2010?
10-12-2017 #66
noob question here with it being the first time tapping a hole my self if the linear rails holes are 4.5mm what would the tap size be to the aluminium plate its attaching to?
10-12-2017 #67
If the holes really are 4.5 mm diameter in the rail they are expecting you to use M4 cap head bolts to allow some adjustment. You need a 3.3 mm drill for the pilot drill, followed by an M4 x 0.7 pitch tap (coarse thread).
But I would expect a 25 mm rail to use M6 cap heads? If so these would need a 5mm pilot hole then an M6 x 1 pitch tap (coarse thread).
10-12-2017 #68
What's with the parquet bed?!
10-12-2017 #69
10-12-2017 #70
BUILD LOG: All steel, no welding, 2000x1300x250mm
By eurikain in forum DIY Router Build LogsReplies: 55Last Post: 28-06-2017, 12:51 PM -
BUILD LOG: Small workshop CNC router, steel base, planning on ATC
By spresv in forum DIY Router Build LogsReplies: 24Last Post: 07-02-2017, 04:28 PM -
Steel base
By D-man in forum Items For SaleReplies: 4Last Post: 09-05-2016, 01:22 PM -
Redesign...Steel is now Extrusion
By FlyHighRC in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 30-10-2015, 10:09 PM
. As a good rule of thumb tap drill size is screw diameter - thread pitch, so for M4 normally 0.5mm pitch would mean a 3.5 mm drill.
