18-12-2017 #10
This is very important! If using KJN aluminium to cut your extrusions you must have the pieces cut on the same day at the same time. They can offer a very high degree of repeatability but not if they have to reset the machine.
How accurate are KJN cuts I just had cut my MDF bed cut to 135.1cm *100cm based on my cad models and it dropped into place perfectly so I'd say at least for me there cuts were very accurate. I also had them cnc drill holes in my frame so I could assemble it with m12's instead of corners.Last edited by Desertboy; 18-12-2017 at 03:14 PM.
BUILD LOG: All steel, no welding, 2000x1300x250mm
By eurikain in forum DIY Router Build LogsReplies: 55Last Post: 28-06-2017, 12:51 PM -
BUILD LOG: Small workshop CNC router, steel base, planning on ATC
By spresv in forum DIY Router Build LogsReplies: 24Last Post: 07-02-2017, 04:28 PM -
Steel base
By D-man in forum Items For SaleReplies: 4Last Post: 09-05-2016, 01:22 PM -
Redesign...Steel is now Extrusion
By FlyHighRC in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 30-10-2015, 10:09 PM
