been over thinking again lol but that's the fun of reading tons of posts on this forum and coming up with new idea's (stolen idea's). just out of interest whats the price difference between good stepper motors and servo motors now? because of my high z axis i need to make the gantry very beefy but after reading some more for 3d work the z front plate needs to be light so i will update soon on an updated version and see what you think.
31-12-2017 #2
What i think for sure is this:
Do not buy anything more until you have definitely finished your drawing and have it all clear 100%. That includes rails, screws, motors, board, etc. It will be just throwing money in the bin. And yes, we have done it all.
One more thing to note: Everyone here thinks he is a top machine designer. Nothing wrong with that. And in reality here we could see most of the best build ever worldwide. But what i learned from experience is that even if you overthink your machine, you always mess something, even small. Once you make the machine though, use the machine 1 year 8h per day, maybe make another one later, revise a couple of times the design customising it for clients, then this machine becomes better and better.
What i am saying is: assume you will make errors, if someone has made a nice working machine and you like the design, ask, listen and copy shamesly. Do not over think and over invent. look for good working designs, easy to make at home.
31-12-2017 #3
Thanks boyan, i have not ordered anything apart from the steel for the frame and while spending the whole of january welding it together i will wait until that is completed before confirming other parts to order. i have seen loads of build logs on here from people who have rushed in and bought the parts before asking and i will not be making that mistake. i am not expecting this machine to turn out how it looks in cad software or in my head but what i am expecting is knowledge from trial and error. that is the way i always like to learn because if you can fix an error then thats a new skill you get to keep :)
31-12-2017 #4
Morning, unsure what you decided for drivers but if going the Leadshine AM882 route I'd order them now took about a month for mine to arrive from Hong Kong.
You can buy EU equivalent Leadshine EM806's but they're twice the price and the specifications seem identical both made by leadshine. AM882's you will not find available from UK seller if you do link me to him please lol so i can buy another 4. The only difference I can see between the EM806 and AM882 is they have different dip switch settings relating to auto motor setup but both support autotuning making this an non issue.
Don't buy 2nd hand like I did didn't save enough money to pay for the non working one I got I ended up buying a new one for £60 delivered, quick tip reduce the chances of important tax by making 4 separate orders to 2 different address's.
Personally I'd order the Hiwin's and ballscrew in at same time and from personal experience this time I would make the Hiwin's 20cm longer than the ballscrews. I'd want the Hiwin's and ballscrews before I started to make the frame after all the frame has to fit the Hiwin's and ballscrews not the other way round. You can't practically cut ballscrews down I rang a company in Leicester that specialise in ballscrew repairs to see how much to end machine a ballscrew was. It was about twice the price of buying the ballscrew from China with BK/BF fittings for the machining only.
If I had to order the Hiwin rail in UK I would use cncforyou which sells original carriages but a clone rail but I would just order from China/HK as my experiences so far have been mostly positive.Last edited by Desertboy; 31-12-2017 at 10:39 AM.
31-12-2017 #5
I would only ever buy Leadshine drives from a reputable source, as there are a lot of counterfeit drives about.
Personally, I've often wondered why the AM series got discontinued so quickly, but I suspect it was to do with forgeries. IIRC Leadshine superseded to the EM series in well under 2 years, but by that point you could pick up the AM drives cheap in lots of places. So either there was some major internal redesign, or they needed to get a step ahead of forgeries. I suspect the latter, and the AM firmware was easy to retrieve (the Chinese are renowned for their ability to extract such things, using methods you wouldn't think were possible), and the EM not so, which is why it's not yet been copied.
Most older digital drives are copies of Leadshine, which in turn were re-designed copies of Geckos, so you can't say Leadshine are just a victim in the whole counterfeit drive area, but they at least build reliable drives, and didn't deny for years they had an inherent design flaw which meant they could randomly blow up during power up (it's a shame JohnS isn't around anymore, as it's what ultimately forced him to use Chinese drives, and he liked a good rant on the subject).Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
31-12-2017 #6
I don't know if anyone has done a controlled side-by-side comparison of the AM882 and the EM806. I bought the EM drives for my machine as I was fed up with buying things that seemed to go obsolete almost as soon as they were delivered and the EM series was still fairly new on the street, with supposedly better anti-resonance algorithms, etc. That was around 3 years ago but the AM drives are still going strong! However, I can say that I am very happy with my EM drives - no resonances ever been apparent, and the anti-stall is very useful if for some reason the gantry has gone out of square and loads get too high on rapid feed. Machine stops quickly without tearing itself apart. Would the AM drives have worked as well? Dunno!
One day I'll make up a serial cable and try to set up the autotune properly. Still slightly confused about how that's supposed to work with a dual-motor setup as you clearly can't do it with the motors connected to the ballscrews, but it doesn't seem to make sense to try to tune the motors when they're unloaded.
31-12-2017 #7
I have an Am and two EM's on my milling machine and I can't see much of a difference to be honest.
However, for my new router I am using four EM's. As you say, Neale, the stall function really works, I had my milling machine travel out of bounds without a limit switch and as soon as it hit the end, the driver stopped it preventing any damage. Also good for when you make a mistake and go too severe with your cut, it soon stalls the movement and prevents further damage.
My thought is, if you can afford it, buy EM's from Zapp, they are actually quite reasonably priced and it's just a one off expense anyway and it supports a UK firm. If you really are on a very tight budget, buy AM's from China, but expect customs duty, some wait and at the end of the day, you are not saving much more than a round of beers, if that.Last edited by Edward; 31-12-2017 at 01:29 PM.
The Following User Says Thank You to Edward For This Useful Post:
31-12-2017 #8
That's what we need is a side by side comparison, when I build my next router I might go with EM806's (Although planning the easy servo drives with matching motors) just to compare with same toroidal PSU setup. They are plug compatible so could relatively easy swap them over just for testing.
They don't sell EM806's on alixpress and the suppliers I contacted said they don't sell them in Asia they are only sold in US and Europe but I always take what suppliers say with a pinch of salt lol.
On the clone issue I think it's how good a clone is it? If the clone performs and works exactly the same then the issue is slight, if it's a poor clone then problems occur.
I have no idea if my AM's are clones but the internals look identical when I stripped them down and they all seem to perform the same. Almost silent performance if I set the microsteps to 32.
https://www.youtube.com/watch?v=O4_u5ov-9cc
I'm going to set them to 8 for now which makes them sound like normal whiney steppers but more torque of course.Last edited by Desertboy; 31-12-2017 at 01:41 PM.
31-12-2017 #9
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
31-12-2017 #10
What's your opinion on
http://www.leadshineusa.com/productt...y-servo-motors
If I understand it these are not real servos but somewhere in betweenLast edited by Desertboy; 31-12-2017 at 02:45 PM.
BUILD LOG: All steel, no welding, 2000x1300x250mm
By eurikain in forum DIY Router Build LogsReplies: 55Last Post: 28-06-2017, 12:51 PM -
BUILD LOG: Small workshop CNC router, steel base, planning on ATC
By spresv in forum DIY Router Build LogsReplies: 24Last Post: 07-02-2017, 04:28 PM -
Steel base
By D-man in forum Items For SaleReplies: 4Last Post: 09-05-2016, 01:22 PM -
Redesign...Steel is now Extrusion
By FlyHighRC in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 30-10-2015, 10:09 PM
