07-01-2018 #24
Now I get it, smart! ;)
I have been using a dti alot lately.. was so hung up on aligning my rails (went fine) that I more or less forgot/neglected the ballscrews, bearings and ballnut..
If you get a dti make sure it has a good holder (if its called that) with a strong magnetic base.
Mine is utter crap and its frustrating when you hand turn the ballscrew with everything mouted from one end almost to the next and the dial tip just moves off the reference. Not worth the 5-20 you save on a cheap holder :)
BUILD LOG: All steel, no welding, 2000x1300x250mm
By eurikain in forum DIY Router Build LogsReplies: 55Last Post: 28-06-2017, 12:51 PM -
BUILD LOG: Small workshop CNC router, steel base, planning on ATC
By spresv in forum DIY Router Build LogsReplies: 24Last Post: 07-02-2017, 04:28 PM -
Steel base
By D-man in forum Items For SaleReplies: 4Last Post: 09-05-2016, 01:22 PM -
Redesign...Steel is now Extrusion
By FlyHighRC in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 30-10-2015, 10:09 PM
