  1. Ok, this is what I plan to do... the top shows the existing screw, very simple, very crude.
    The lower two diagrams show the proposed 10x2G replacement, with a pair of 8x16x5 thrust bearings retained by a circlip and 12mm washer inboard and an M8X1.0 nut outboard to adjust endfloat. I'll probably extend the outboard shaft to allow me to fit a zeroable micrometre dial with a backing dial mounted on the bearing block.
    Comments?
  1. ACME / Trapezoidal leadscrews
    By ZeroCount in forum Lead Screws, Nuts & Supports
    Last Post: 08-03-2020, 09:29 AM
  2. Belt Driving your leadscrews !
    By Lee Roberts in forum Lead Screws, Nuts & Supports
    Last Post: 05-02-2011, 09:14 AM
  3. Restoring a Kerry 1124 - Info and photos required
    By Noname in forum Milling Machines, Builds & Conversions
    Last Post: 27-12-2010, 02:45 PM
  4. Motors and leadscrews
    By Tom in forum Gantry/Router Machines & Building
    Last Post: 29-05-2009, 10:37 PM
  5. Ideas for fitting leadscrews
    By irving2008 in forum Lead Screws, Nuts & Supports
    Last Post: 11-11-2008, 10:05 PM
