Thread: Pacer Cadet What software?
Do something about the font you are using !
Have a look at CamBam, FreeCAD, CAMotics.
Members of the CamBam forum can make a post processor (only for use with CamBam) for your machine if you can supply the correct information regarding it's gcode dialect.Last edited by EddyCurrent; 06-12-2017 at 12:36 PM.
06-12-2017 #2
Thanks for that will look into this amongst everything else, it's the post processing that is the key by all counts. Tried to alter the text but not happening.
07-12-2017 #3
The problem I have with Fusion 360 is that it's free, there is quite a steep learning curve on how to use it, when the day comes when it's not free I'd have wasted all that time and effort learning it and then I'm back to square one. Open source software is something I use as much as possible if it does the job but Fusion 360 is not open source.
07-12-2017 #4
Thanks Eddy for ali your advice it's a good point
22-01-2018 #5
I wouldn't worry about that, I'd worry that the documentation isn't up to date with the development and that they break it, you get the broken version, and you have no control over their fix timetable, you got it free, what do you mean SLA? :-)
Autodesk are one of the nastiest companies in CAD/CAM and actively buy up and integrate or kill anything that might threaten their margin, the sooner they go the way of Carillion the better.You think that's too expensive? You're not a Model Engineer are you? :D
conect 121 / cadet lathe manual/user's guide anyone?
By Rabs in forum Conect LathesReplies: 50Last Post: 01-07-2022, 04:11 PM -
Pacer cnc to work Rhino
By rainboweyes in forum Rhino 3DReplies: 4Last Post: 06-09-2017, 05:28 PM -
FOR SALE: Pacer AXYZ Compact CNC router and Pacer 2500HD cnc router
By vendka in forum Items For SaleReplies: 0Last Post: 07-04-2017, 11:17 AM -
AXYZ Pacer 900
By burnooot in forum AXYZ RoutersReplies: 1Last Post: 27-03-2017, 08:50 PM -
Pacer 900
By burnooot in forum Machine DiscussionReplies: 14Last Post: 09-03-2014, 12:36 AM
