Thread: My new 6040 improvement plan.
I don't think replacing the x axis rails with supported rails will yield much benefit. It looks more work than its worth so I'm going to try a simpler approach.
I'll replace the back panel (3mm aluminium) with 10mm steel plate or possibly 25mm aluminium.
At the top and bottom of my Z axis assembly, I'm going to fit a runner wheel (or 2), adjusted to run tightly along the back plate (rolling along the x axis direction). For the spindle to rock back or forth, it will need to flex the back plate as well as the 2x20mm rails.
I currently cannot see any flexing left and right, just back and forth.
The mod should be cheap, but I will probably need to pay someone to mill some components for me.Last edited by PaisleyPCdoctor; 17-12-2017 at 09:25 PM.
	17-12-2017 #2
I also plan to mill the spindle mounting plate to allow a little tram adjustment left/right tilt. Back/forward tilt should be easy with shims.
But no point until I improve rigidity.
	17-12-2017 #3
I wouldn't bother tbh... just get it up and running. If you want to revisit ideas later on after having actually put some use on it then do so.
The biggest flex for me on the unsupported rails came from the ability for it to twist (eg apply a force on the bottom of the cutter which is after all where the cutting forces come from) pushing it towards the back of the machine. The top rail will bend forwards and the bottom rail will bend backwards. The deflection is very measurable (and even visible) with quite moderate loads. Your solution of the rear panel doesn't do anything to change that, nor does a single wheel. Two wheels would go someway to solving half the equation (the rail being pushed towards the back) but not the other half (the rail being pulled away from the back). Even then I doubt you would see much benefit with the wheel slop/flex/wear.
In the nicest way possible, don't try to re-invent the wheel on this one. Get your machine up and running, get some use on it and if you find you need to improve on it then feel free, but in all honesty you'll probably come to the conclusion that you are better off building a new machine than trying to improve the 6040.Last edited by Zeeflyboy; 17-12-2017 at 09:32 PM.
The Following User Says Thank You to Zeeflyboy For This Useful Post:
	17-12-2017 #4
Zee flyboy,
I appreciate your input. Here my thinking.
If you push on spindle, the axis shafts flex. The pivot point is the ball screw, top rod flexes forward, bottom rod flexes back. Vice versa if you pull on spindle.
During this motion, the gantry stays stationary.
The backplate is attached to gantry.
Imagine the gantry didn't need to move left/right on x axis. If I placed a piece of metal from top of z axis to backplate and bottom of z axis to backplate- it would support the spindle and it wouldn't flex. Assuming of course back plate was rigid.
To allow x as is movement- Ill use wheels on the supports.
It'll work.
	17-12-2017 #5
Yeah but in your example of the Z-axis bolted to the gantry, it can't pull away... a wheel isn't attached to the gantry it just rides on it. Sure it can't push into the gantry (well, beyond what degree flex of the wheel allows) but it can pull away from it. That's not even getting into the problem with swarf getting trapped under the wheels and wearing down the relatively soft aluminium surface.
What you need is something that can't push towards the gantry or pull away from it - ie a supported rail. Round supported rail however has the drawback that the shitty bearing becomes the weak point (even shittier than a fully round rail bearing is)... enter profile rail. Now you come full circle to what I was saying in the first place which is that the unsupported round rail is just inherently inferior to profile rail for milling anything substantial.
Honestly, what you are suggesting is a waste of time - imo the improvements will be minimal if noticeable at all. Combine that rear plate with proper linear rails and now you have a substantial improvement but are at the mercy of the next weak link. And onwards the chase continues.
Listen to me or don't, but I would sincerely suggest you just get cracking with your machine without any major effort/changes and take it from there. I would say after a few mods and chasing your tail you will come to the conclusion that it's better to just chalk it up to a good entry machine for learning/playing around and decide to build your own one rather than constantly trying to work around the inherent weaknesses of the design. Either that or you will decide that for whatever your intended purpose is, it's just fine.
Note that when I say the inherent weaknesses of the design, I'm not just talking about the unsupported rails... there are MANY issues with these machines and to address them all you would effectively end up building a new machine anyway - which is what I am now doing myself.
Just trying to save you some time and money in the process. Up to you if you want to heed that or not.Last edited by Zeeflyboy; 17-12-2017 at 10:52 PM.
	17-12-2017 #6
I see what you mean about it moving away from wheels, but that would take a lot more force and I don't see how it would happen. The workpiece can only push from the very bottom.
The supported rail was my plan, but I seen the guy on YouTube done it and it didn't help at all. Maybe with the fat backplate though. The way the ballscrew is attached to the bearings just now make it look like a big job. I'll need to have a good think how to do it though.
BTW, I'm still using the machine in between mods. I did specifically buy it with intention of modding it and learning. I knew the weaknesses when I bought it, if anything it was a lot better than I'd expected. I didn't get disappointed. It's a hobby machine. I'm hobbying.
	17-12-2017 #7
I think you underestimate how little it takes to produce chatter
Again, the supported rail that you are thinking of is not what I suggest. Supported rail is barely better than round rail... What I am suggesting is profile rail. Everything else you do without doing that is just really little more than pointless.The supported rail was my plan, but I seen the guy on YouTube done it and it didn't help at all. Maybe with the fat backplate though. The way the ballscrew is attached to the bearings just now make it look like a big job. I'll need to have a good think how to do it though.
Good, and I applaud garden shed engineering - it's quintessentially British. Even so, there is limited value in repeating the mistakes of others that have gone before you. One of the great things about our species is the ability to progress based on prior learnings of others rather than being doomed to constantly be stuck in a cycle of repeating the same failures... There is a reason why anything above the absolute most entry level machines use profile rail across hobby/industry and it's not because they weren't creative enough to come up with weird and wonderful solutions like wheels.BTW, I'm still using the machine in between mods. I did specifically buy it with intention of modding it and learning. I knew the weaknesses when I bought it, if anything it was a lot better than I'd expected. I didn't get disappointed. It's a hobby machine. I'm hobbying.
	17-12-2017 #8
Okay, I'll look at profile rails.
In your opinion, what are the Chinese profile rails like? Their prices look fine, but most of the branded ones I've seen are just far far too much for me.
	17-12-2017 #9
I could possibly ADD a really fat supported rail on the other side of backplate, mounted to z axis assembly over and under the backplate.
hmm.
	17-12-2017 #10
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
NEW MEMBER: Hi all, Ive got a plan, hopefully its a good one!
By Benja in forum New Member IntroductionsReplies: 6Last Post: 25-06-2016, 12:58 PM -
Mach 3 Driver test results & improvement
By Joe in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 15-12-2013, 11:53 AM -
NEW MEMBER: Designer with a plan looking for advice
By bigstu67 in forum New Member IntroductionsReplies: 2Last Post: 10-10-2012, 06:04 PM -
So... what do you plan to do over the hols?
By irving2008 in forum General DiscussionReplies: 5Last Post: 23-12-2008, 09:03 PM
