    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,987. Received thanks 373 times, giving thanks to others 9 times.
    I suspect Nick was on the sauce last night ;-)
    But his point was if the basic machine can't hold tight tolerances, then everything is else is superficial.
    Shielding is not as big a problem as people often think it is. None of my Denford machines came with anything shielded other than two sensors on the Triac mill. Everything else, including the spindles (VFD on the Cyclone lathe, and DC spindle on the Triac) used unshielded wiring, but then they're not using TTL level logic for inputs.
    I get that, however, as it's often repeated on this forum- not all China cnc are the same. Much of the reputation was for poor electronics was from early controller boards and VFD etc. I was very careful to get one with a newer controller (HC4-IV), decent steppers and a good spindle. There's nothing inherently wrong with the table and gantry design.
    I know my way around electronics, so I wasn't bothered about doing some extra work to improve it. Even without the improvements, it hasn't glitches on me yet. It's done everything I've asked of it perfectly well.
    At £1800 it's not the cheapest out there- I certainly wasn't going to spend £10k+
    Plenty of people making really cool stuff with 6040's.
  3. The Following User Says Thank You to PaisleyPCdoctor For This Useful Post:
    There is plenty wrong with the basic machine design.
    If you're only doing softer materials with light cuts, it's not a problem, but if you try pushing the spindle, you'll get resonance/poor cuts.
    If you have a DTI, try setting it up against the spindle noseat a typical cutting height, then apply some pressure against the spindle and see how much deflection you get. Having three sets of unsupported rails between the bed and the spindle does not produce good rigidity.
    Then try testing for backlash. The setup used for the ballscrew endfloat is a couple single row ball bearings (which are usually cheap rubbish), with preload controlled via a single nyloc nut. Then the stepper motor couplers will most likely be cheap aluminium bellow type, which will crack if driven hard.
    Plus the general tolerances will be questionable.
    And in case you're wondering why I know all this, is I bought a 3040z as the base for a digitizing machine, knowing full well it's shortcomings. It does it's job as digitiser, but I certainly wouldn't want to use it as a router and expect it to produce good quality cuts and not need continual fettling.
  5. #4
    I understand what you're saying and I agree to a point. Of course it's not going to be as good as a £10k+ machine, but I don't think it's as bad as you say. The newer models are build far better than the older (coupla years only) models. Either way, my only option is to try to improve in its weaknesses as much as I can and learn whilst doing it. It's fun anyway.
    Take a look at this video (especially around 8minutes in). He's on my school of thought that the wiring is the main problem now, not the mechanics.
    https://youtu.be/fdfJ_WZTxJY
  6. #5
    Is it supported or unsupported rails?
    If its for a hobby and occasionally using it, there is nothing wrong. / Did i just say that??? / . But if you are trying to make something and sell it... And not to speak of if you are accepting online orders. One needs a totally reliable machine for this. Or it will be pulling hair 24h
    The y axis rails are supported, the x axis is 2x20mm unsupported shafts (and ballscrew).
    Z axis 2x13mm unsupported shafts with ballscrew.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. NEW MEMBER: Hi all, Ive got a plan, hopefully its a good one!
    By Benja in forum New Member Introductions
    Last Post: 25-06-2016, 12:58 PM
  3. Mach 3 Driver test results & improvement
    By Joe in forum Artsoft Mach (3 & 4)
    Last Post: 15-12-2013, 11:53 AM
  4. NEW MEMBER: Designer with a plan looking for advice
    By bigstu67 in forum New Member Introductions
    Last Post: 10-10-2012, 06:04 PM
  5. So... what do you plan to do over the hols?
    Last Post: 23-12-2008, 09:03 PM
