Thread: My new 6040 improvement plan.
14-12-2017 #24
I never realised the ferrite ring was still mounted in that bit of the photo. I was on about the silver box mounted to the side of the enclosure at the bottom of the photo. Technically any power components shouldn't be directly mounted to the case, they should be mounted on a sub-plate.
As there's a ferrite ring, I wouldn't bother shielding any of the power cabling in the case. Ferrites are very effective at stopping the noise that can potentially cause problems. I would however use good quality shielded and twisted pair wiring for the VFD speed control wiring, as noise on that can cause spindle speed instability. The control wiring less so. It will all be 12 or 24V, and it would take a lot of interference to cause any problems there.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
NEW MEMBER: Hi all, Ive got a plan, hopefully its a good one!
By Benja in forum New Member IntroductionsReplies: 6Last Post: 25-06-2016, 12:58 PM -
Mach 3 Driver test results & improvement
By Joe in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 15-12-2013, 11:53 AM -
NEW MEMBER: Designer with a plan looking for advice
By bigstu67 in forum New Member IntroductionsReplies: 2Last Post: 10-10-2012, 06:04 PM -
So... what do you plan to do over the hols?
By irving2008 in forum General DiscussionReplies: 5Last Post: 23-12-2008, 09:03 PM
