    Quote Originally Posted by PaisleyPCdoctor View Post
    My next area that I'm going to look at is the flexing of the unsupported x-axis 20mm linear bearing shafts.
    Give us a pic.
    Here are pictures of the y axis assembly. Excessive flex in x axis direction.
    Okay- some interesting results with dial gauge.
    In middle of x axis (must be worst deflection zone), I can deflect the machine up or down a staggering 1.3mm! (worried).
    I then thought- to prove the theory- deflection must be better or even minimal at either end of X-axis...
    Its better, but still 1mm. So looks like its actually entire gantry flexing. Opens new possibilities.
    Looking at Y-axis bearings, I previously closed the allen key sdjuster until it stopped, no further. I gave all 4 side screws a wee tweak tighter and deflection has been reduced to 0.4mm at ends and 1.1mm middle of Y axis.
    I think theres another adjuster on top of bearing. I'll need to dismantle bed to get to it.
    SIGH!
    Go on mate, explain to me just how good they are, and how you'll fix yours :D
    Still incomprehensible to you? :D
    Thanks for that constructive advice, I'll try that!
    Now where's that middle finger emoji gone?
    Here you go -
    You can polish it but then it will just be a shiny one ;-)
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. NEW MEMBER: Hi all, Ive got a plan, hopefully its a good one!
    By Benja in forum New Member Introductions
    Last Post: 25-06-2016, 12:58 PM
  3. Mach 3 Driver test results & improvement
    By Joe in forum Artsoft Mach (3 & 4)
    Last Post: 15-12-2013, 11:53 AM
  4. NEW MEMBER: Designer with a plan looking for advice
    By bigstu67 in forum New Member Introductions
    Last Post: 10-10-2012, 06:04 PM
  5. So... what do you plan to do over the hols?
    Last Post: 23-12-2008, 09:03 PM
