Thread: My new 6040 improvement plan.
17-12-2017 #1You think that's too expensive? You're not a Model Engineer are you? :D
17-12-2017 #2
The main gain was in Y-axis bearings.
They are adjusters. When they are tight, there is no noticeable flex/movement on the gantry. I tighten til they stop, then quarter turn to nip up. Gantry feels rock hard.
When I loosen the grub screws, the gantry flexes as if it's on rubber mounts. Difference is remarkable.
I'm just left with the flexing of the 20mm unsupported x-axis shafts. There's a youtube video where the guy replaces them with supported rails, but improvement was MINIMAL at best. Waste of time.
I have a better, cheaper and easier solution. Just sketching out the plan and I'll post it.
17-12-2017 #3
17-12-2017 #4
But that simply isn't how these bearings work, there is no pre-load adjustment... they are just a few rows of bearings inside a tube. You are achieving a reduction in slop most likely by forcing them out of alignment and thus introducing an increased load on one side. It achieves the goal but the problem is that the load isn't evenly distributed and wear will likely be accelerated.
Whatever works for you, but they are retainer screws not adjustment screws.
Supported rail doth not equal profile linear rail. My current machine is effectively a 6040 with proper 20mm profile rails and the difference is very obvious compared to the old machine... I don't need a guy on youtube, I've extensively experienced both. Of course even with proper rails you are still left with the general somewhat lightweight design but it's still a significant improvement over the previous model I had with unsupported rails like yours.I'm just left with the flexing of the 20mm unsupported x-axis shafts. There's a youtube video where the guy replaces them with supported rails, but improvement was MINIMAL at best. Waste of time.
I'm not belittling you, you are obviously keen to get stuck in and learn - just be aware that despite what you may think at the moment, those unsupported rails (and to a lesser extent the supported rail on the bottom) are a limiting factor in this machine which you will need to learn to work around and will limit the level of tolerance and finish you can ultimately achieve in harder materials.Last edited by Zeeflyboy; 17-12-2017 at 08:29 PM.
The Following User Says Thank You to Zeeflyboy For This Useful Post:
17-12-2017 #5You think that's too expensive? You're not a Model Engineer are you? :D
17-12-2017 #6
If they are simply retaining screws, then fine- they weren't fastened when they built the machine and they are now in their proper location!
It's not like I've torqued them into the rod. Like I said, I screwed them in until they touched/reached resistance then gave them a QUARTER TURN.
The grub screws are obviously put there for a reason and being fully unscrewed (as they were) clearly serves no purpose whatsoever.
The bearings still run smoothly, no crunching or grinding.
The bearings were sloppy, now they are not. Moving on...
17-12-2017 #7
I don't think replacing the x axis rails with supported rails will yield much benefit. It looks more work than its worth so I'm going to try a simpler approach.
I'll replace the back panel (3mm aluminium) with 10mm steel plate or possibly 25mm aluminium.
At the top and bottom of my Z axis assembly, I'm going to fit a runner wheel (or 2), adjusted to run tightly along the back plate (rolling along the x axis direction). For the spindle to rock back or forth, it will need to flex the back plate as well as the 2x20mm rails.
I currently cannot see any flexing left and right, just back and forth.
The mod should be cheap, but I will probably need to pay someone to mill some components for me.Last edited by PaisleyPCdoctor; 17-12-2017 at 09:25 PM.
17-12-2017 #8
I also plan to mill the spindle mounting plate to allow a little tram adjustment left/right tilt. Back/forward tilt should be easy with shims.
But no point until I improve rigidity.
17-12-2017 #9
I wouldn't bother tbh... just get it up and running. If you want to revisit ideas later on after having actually put some use on it then do so.
The biggest flex for me on the unsupported rails came from the ability for it to twist (eg apply a force on the bottom of the cutter which is after all where the cutting forces come from) pushing it towards the back of the machine. The top rail will bend forwards and the bottom rail will bend backwards. The deflection is very measurable (and even visible) with quite moderate loads. Your solution of the rear panel doesn't do anything to change that, nor does a single wheel. Two wheels would go someway to solving half the equation (the rail being pushed towards the back) but not the other half (the rail being pulled away from the back). Even then I doubt you would see much benefit with the wheel slop/flex/wear.
In the nicest way possible, don't try to re-invent the wheel on this one. Get your machine up and running, get some use on it and if you find you need to improve on it then feel free, but in all honesty you'll probably come to the conclusion that you are better off building a new machine than trying to improve the 6040.Last edited by Zeeflyboy; 17-12-2017 at 09:32 PM.
17-12-2017 #10
Zee flyboy,
I appreciate your input. Here my thinking.
If you push on spindle, the axis shafts flex. The pivot point is the ball screw, top rod flexes forward, bottom rod flexes back. Vice versa if you pull on spindle.
During this motion, the gantry stays stationary.
The backplate is attached to gantry.
Imagine the gantry didn't need to move left/right on x axis. If I placed a piece of metal from top of z axis to backplate and bottom of z axis to backplate- it would support the spindle and it wouldn't flex. Assuming of course back plate was rigid.
To allow x as is movement- Ill use wheels on the supports.
It'll work.
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
NEW MEMBER: Hi all, Ive got a plan, hopefully its a good one!
By Benja in forum New Member IntroductionsReplies: 6Last Post: 25-06-2016, 12:58 PM -
Mach 3 Driver test results & improvement
By Joe in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 15-12-2013, 11:53 AM -
NEW MEMBER: Designer with a plan looking for advice
By bigstu67 in forum New Member IntroductionsReplies: 2Last Post: 10-10-2012, 06:04 PM -
So... what do you plan to do over the hols?
By irving2008 in forum General DiscussionReplies: 5Last Post: 23-12-2008, 09:03 PM
