    Superb stuff Wal - that's line I'm heading towards for my guitar logo's etc. I'll be picking your brains on this topic I'm sure as my design/build gets off the ground.
    Francis
    https://milsomguitars.weebly.com/
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 15-12-2024 Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Quote Originally Posted by fwm891 View Post
    Francis
    Hi Francis,
    I'll try to drop you a line this evening - just working on a project this weekend and it's all consuming..!
    Had a quick look at your site - my word, you build some beautiful guitars..!
    Wal.
    Sent from my HTC One M9 using Tapatalk
  3. The Following User Says Thank You to Wal For This Useful Post:
  4. #13
    Hi Wal
    Where do you get your pearl cutters from ? and what kind of speed feed rates are you using. I liked your dream or die video. Was that an arbortech turboplane that your'e using.
    Andrew
  5. #14
    Well Wal, I've been playing around with the WorkBee for a while now here's one of the latest headstock inlays I've done...
    The MOP inlay was cut with 0.5 and 0.3mm end mills, the wood inlays 1.3mm end mill. Feeds @ 20k rpm for the inlay circa 1.5 mm/sec with 0.3mm depth of cut. The wood inlay pockets were cut circa 5mm / sec 1.2mm depth. I remembered you saying about super gluing your MOP to an ali sheet and soak in boiling water to release the parts. I ended up super gluing to thin MDF and soaking in boiling water. The MDF just swells up and flakes away.
  6. #15
    Wal's Avatar
    Andrew,
    Thanks for your kind words, I'll be posting about that Dream or Die piece in the next few minutes as there are a couple of questions I have regarding grain filler... Anyway, I buy my cutters from APT in Glasgow. I use ordinary two-flute carbide cutters - the same as I use for aluminium/brass/wood. Heh - they seem to work for everything! A couple of links:
    https://www.shop-apt.co.uk/end-mills...d-carbide.html
    https://www.shop-apt.co.uk/micro-dia...ide-60hrc.html
    Feeds and speeds are very conservative when using the smaller cutter - less than 0.6mm and I'm running around 1-1.5mm/sec - yep, very slow but luckily inlays tend to be pretty small so it's not too much of an issue. The larger 52mm surfacing tool I use is from Wealden:
    https://www.wealdentool.com/acatalog/Surface-Trim.html
    Francis - that's an awesome looking headstock - that WorkBee is certainly doing the business for you! Good call on the MDF - I take it that you don't get any issues with fibres sticking to the back of the inlay pieces?
    Wal.
  7. #16
    Thanks Wal - no any fibres that do stick a light rub on fine wet-n-dry removes them - I use APT as well for my cutters - very prompt service.
  8. #17
    Hi Wal
    Thanks for the links, i'll check them out.Your right about the slow speed. I cut my surname out on Sunday (12 Letters Polish name !) 6 passes with a 0.5mm cutter must have taken 45 mins. My cutters are a bit long so I didn't want to push them too much. The cutters on the apt site are a little short on the 0.5mm dia, only 1mm deep my pearl is usually 1.5mm thick. That surfacing cutter looks really useful.
    Andrew
  9. #18
    Wal's Avatar
    Quote Originally Posted by the great waldo View Post
    Hi Wal
    Andrew
    Andrew, they also stock long necks:
    https://www.shop-apt.co.uk/2-flute-l...lls-68hrc.html
    Wal.
  10. The Following User Says Thank You to Wal For This Useful Post:
  11. #19
    Hi Wal.
    Thanks for that, I'll have to give my plastic friend a bashing.
    Cheers.
    Andrew
  12. #20
    I've done a bit of MOP machining as well, also for guitar inlays. Your technique of gluing the blanks to a plate for machining sounds excellent. I made a small fixture from aluminum to hold a 1" x 1.5" MOP blank. as shown in the photo. I cut out a lizard figure, and cut the corresponding pocket to inlay it into. There is a photo of a finished inlay, although this one happens to be cut from African blackwood, not MOP;
    My apologies for the imperial measurements -- we colonials are rather backward, you know!
