Thread: Aluminium Extrusion Router Build
I use a Pilz safety relay which is tripped by e-stop and by fault signals from stepper drivers (particularly if one of the dual X drive steppers stalls so the machine doesn't tear itself apart). The relay was a cheap "new but obsolete" one that cost £25 from eBay, which is the main reason I used one. However, it has multiple contact sets so I switch the stepper enable signal and the CSMIO motion controller e-stop signal (both of which should stop stepper movement almost instantaneously) and the stepper motor power supply mains input (which would stop steppers but not quite so immediately). One reason to switch the power is not so much for safety (although it was easy to do anyway) but to enable me to reset the stepper drivers in case one of them does go into fault condition. If a motor stalls (a rare event), I can reset by hitting e-stop and then resetting the machine. You need to consider how you would reset stepper drivers if they are configured to "fault" on error. Just a thought.
28-10-2018 #2
Hi Neale, thanks for the great reply. What you've described is roughly what I had in mind. I got a used Schmersal safety relay, and intend to use the outputs to stop the drivers and inverter, and signal the CSMIO controller. What I had missed was the fact that you needed to kill the power to the drivers to reset them after a fault or stall. I might just add a button to switch the driver contactor on and off to reset the drives and then reset the safety relay.
01-11-2018 #3
Hi Nick
The answer is for a DIY machine that you are the only user then it’s what you feel happy with.
My mk1 just used the estop pin on the breakout board and relied on that to stop sending stepper signals to the drivers and tell Mach3 to stop sending signals to the breakout board.
Had no issues for years with that setup.
For mk2 or 3 (can’t remember!) I made a proper control box with a safer estop circuit and better overall functionality. I have a master relay (not a proper Pilz style but the same principle) that has multiple outputs and one of these drops power to the contactor which controls the linear psu. Other outputs drop the self latch and drop power to the spindle relay which controls the VFD run/stop logic signal and drops the estop pin connection on the breakout board so Mach 3 knows to stop. My drives don’t have stall detect etc so my only reason was a bit more piece of mind. I’m reusing most of this for the current mk4 with the main difference being that axis limit trips are going to be soft stop limit events and not part of the hard estop circuit. I think this last part on limit trips is Dean’s approach and having tried it out on one axis I agree with him.
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
BUILD LOG: DIY Build of Aluminium CNC Wood Router without Workshop & Tools
By WandrinAndy in forum DIY Router Build LogsReplies: 54Last Post: 05-11-2012, 06:22 PM -
FOR SALE: Aluminium Extrusion
By vigen20 in forum Items For SaleReplies: 2Last Post: 24-07-2012, 11:01 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM -
Aluminium Extrusion suppliers?
By m_c in forum General DiscussionReplies: 3Last Post: 12-04-2011, 01:23 AM
