    Quote Originally Posted by NFryer View Post
    I have discovered however that the aluminium cuts a lot like high density hardwoods such as english oak, african blackwood or leadwood, although things need to be well clamped as the aluminium is a bit grabby.
    In other ways it is easier as with a bit of cutting oil you can get really good cuts and keep the cutter cooler than when cutting the hardwoods.
    I cut a 35mm diameter by 12mm deep hole in one of the gantry end plates for the FF12 ballscrew support just with a standard forstner bit.
    With the addition of the cutting oil the bit never got very hot and when I had finished it was cool enough that I could hold it, definitely not the case when cutting the denser hardwoods with the same forstner bit.
    Thanks for that very useful info!
    Andy
    Quote Originally Posted by AndyGuid View Post
    Andy
    I forgot to add that when I used the forstner bits I had to drill a pilot hole through the aluminium as the centre part of the forstner bit won't cut the aluminium. For example I used a 4mm drill for a 36mm forstner bit which also acted as a good guide to get the bit started. Anyhow I got the hole drilled out for the FK12 bearing and test fitted it.
  3. The Following User Says Thank You to NFryer For This Useful Post:
  1. BUILD LOG: New Build, Aluminium Frame Router/Mill
    By Davek0974 in forum DIY Router Build Logs
    Last Post: 31-08-2016, 05:28 PM
  2. BUILD LOG: DIY Build of Aluminium CNC Wood Router without Workshop & Tools
    By WandrinAndy in forum DIY Router Build Logs
    Last Post: 05-11-2012, 06:22 PM
  3. FOR SALE: Aluminium Extrusion
    By vigen20 in forum Items For Sale
    Last Post: 24-07-2012, 11:01 PM
  4. BUILD LOG: Aluminium Extrusion CNC Router Build
    By joshendy in forum DIY Router Build Logs
    Last Post: 10-04-2012, 08:26 PM
  5. Aluminium Extrusion suppliers?
    By m_c in forum General Discussion
    Last Post: 12-04-2011, 01:23 AM
