Thread: Aluminium Extrusion Router Build
Looking good
06-03-2018 #2
Thanks, it's not going too badly. I want the machine to look good, hence countersinking all the cap head bolts, tucking away the motors and not having them stick out and rounding and slope cutting bit like the gantry end plates. It probably won't add any to the performance of the machine but it should look good and sleek.
18-03-2018 #3
I have yet to build a cnc router, but your build looks amazing! No access to a CNC mill or even a manual and you are turning out great parts...
Looking forward to seeing the finished machine and also seeing how it performs.
The design looked spot on and your skill in machining the parts is something to aspire to.
I am guessing you are an expert in woodworking!
Keep the updates coming!
21-03-2018 #4
Hi Richard,
Thanks for the compliments, I have done quite a bit woodworking in the past. I've never however done any metalwork with the accuracy needed to build a CNC machine. I took a while to learn the basics of Fusion 360 and model the design and this has helped a lot with visualising the design. You can also isolate individual parts so it's easy to layout, check and make the parts.
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
BUILD LOG: DIY Build of Aluminium CNC Wood Router without Workshop & Tools
By WandrinAndy in forum DIY Router Build LogsReplies: 54Last Post: 05-11-2012, 06:22 PM -
FOR SALE: Aluminium Extrusion
By vigen20 in forum Items For SaleReplies: 2Last Post: 24-07-2012, 11:01 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM -
Aluminium Extrusion suppliers?
By m_c in forum General DiscussionReplies: 3Last Post: 12-04-2011, 01:23 AM
