Thread: Aluminium Extrusion Router Build
OK You might have been better with 8 wire motors wired in parallel as you would get more speed out of them I take it these are for a router. Although having said that I have no experience with the motors and drive you have.
I have 4 motors on my router running from a 500Va tx at about 70V with no problems. I doubt they would pull more than 8-9 A
Good luck with the build...Clive
23-05-2018 #2
Woohoo! That is one stout build and very clean work, particularly for not having a mill. Seriously, great stuff. I missed the type of linear rails you're using and do you like them? Also, do you have a supplier. I'm in the USA.
Thanks for the compliment about the work I've done and it maybe a bit of overkill but better stout than all flimsy. The rails I'm using are Hiwin 20mm ones together with narrow carriages on the Z axis and the wide ones on both the Y and X axes. I got them custom sized from a supplier here in the UK. If you want them you could try Fred at BST Automation on AliExpress. He sells Hiwin stuff and is a great supplier as I got a set of custom ballscrews from him and had no problems at all with them.
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
BUILD LOG: DIY Build of Aluminium CNC Wood Router without Workshop & Tools
By WandrinAndy in forum DIY Router Build LogsReplies: 54Last Post: 05-11-2012, 06:22 PM -
FOR SALE: Aluminium Extrusion
By vigen20 in forum Items For SaleReplies: 2Last Post: 24-07-2012, 11:01 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM -
Aluminium Extrusion suppliers?
By m_c in forum General DiscussionReplies: 3Last Post: 12-04-2011, 01:23 AM
