The second part of the update is the making of the motor mounting plates which were done in a similar way to the end plates. The 4 bolt slots were first drilled and then tidied up using the router and a end mill. This time I didn't use a template, just a side fence and 2 stops at the front and back. The centre slot was then made bigger then necessary to allow for larger pulleys to be used and because the motor face was not flat and had a raised centre part.
