    Hi everyone, I've got a couple of small updates on the build. Firstly I have made a couple of mounts for the inductive limit sensors on the x axis. I was originally going to mount them under the gantry carriage plate between the ballscrew and the carriages, but I realised that there was no way I could adjust them in that position so I had to move them to the outer edge of the plate. On the top of the plate I fastened a 4 way connector to take the 2 signals back across the gantry and bring power to them via a 4 way CY cable.
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Had you thought about mounting them so that they can slide past the target rather than into it? You can also get away with one limit sensor and a fixed target at each end.
  3. The Following 2 Users Say Thank You to Clive S For This Useful Post:
    Hi Clive, I'm probably missing something very simple, but I just can't visualise how you could only use one sensor to limit travel at either end of the x axis. I didn't mention this explicitly but I'm not having separate limit and home sensors, so I assume that's not possible with one sensor?
  5. #4
    Quote Originally Posted by NFryer View Post
    Ok imagine if you rotate the sensor by 90' and put a target at each end so that the sensor slide over it to trigger.
    the target would not be a the complete end but a small distance from it to enable the gantry to travel to the end before it trips. This is done at both ends.
    I believe Mach can use the sensor to home (then offset the home say 1mm) once homed Mach would then set it to be a limit switch. This way you would only need three sensors with three inputs. (not sure if you have a slaved axis ie two motors)
    If you have two motors to slave you would need two home switches one for each side.
  6. #5
    Hi Clive, once you mentioned rotating the sensor by 90' I understood what you meant, it'a a nice simple way of using one sensor. Unfortunately I've already done the X axis sensors, so can't change them, but it's something to remember if I change the design once built or build another machine.
  1. BUILD LOG: New Build, Aluminium Frame Router/Mill
    By Davek0974 in forum DIY Router Build Logs
    Last Post: 31-08-2016, 05:28 PM
  2. BUILD LOG: DIY Build of Aluminium CNC Wood Router without Workshop & Tools
    By WandrinAndy in forum DIY Router Build Logs
    Last Post: 05-11-2012, 06:22 PM
  3. FOR SALE: Aluminium Extrusion
    By vigen20 in forum Items For Sale
    Last Post: 24-07-2012, 11:01 PM
  4. BUILD LOG: Aluminium Extrusion CNC Router Build
    By joshendy in forum DIY Router Build Logs
    Last Post: 10-04-2012, 08:26 PM
  5. Aluminium Extrusion suppliers?
    By m_c in forum General Discussion
    Last Post: 12-04-2011, 01:23 AM
