Thread: Changed mini lathe to metric
19-12-2017 #23
Super 7, Nick? Makes you sound like a Model Engineer!
I jest - mine is around 35 years old now and would still be in the workshop if it hadn't been "borrowed" by my son when I acquired an old Smart and Brown lathe. The S&B came with a DRO which is somewhat ancient but isn't quite as old as the lathe, I think. Still very useful. Hadn't realised until then just how useful a DRO could be on a lathe, not having used one before. However, for the OP, I suspect that most DRO scales are going to be a bit big to fit on a mini-lathe, or if they do might restrict capacity or be somewhat vulnerable.
If I were looking to make one upgrade to a new or newly-acquired lathe, I think I would go for a quick-change toolpost before DRO. But again, I'm not sure what is available that would fit the mini-lathe category.
The DRO argument, though, is a bit like the metric/imperial conversion discussion going on. It doesn't do anything you can't do with "manual" dials, it just saves a bit of work and reduces the chance of errors. In the same way, you can do a metric/imperial conversion in your head, and if you do it often enough you will get faster. I mentioned the error in my earlier post re just changing the graduations - it's the same approximation, and generally not going to be significant in practice. I've done it often enough as all my lathes have been "single system" and I've had to convert (often mentally) to use "foreign" units, and in both directions. Made the odd mistake doing it, as well...
Mini lathe as a 4th Axis
By Leadhead in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 24-08-2017, 08:53 AM -
Mini Lathe Part
By fragger6662000 in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 15-11-2011, 07:13 PM -
Mini CNC lathe builders
By GeorgeD in forum Lathes, Lathe Rebuilding & ConversionsReplies: 7Last Post: 28-07-2010, 10:00 AM -
A Mini Lathe
By irving2008 in forum Milling Machines, Builds & ConversionsReplies: 19Last Post: 03-05-2010, 04:11 PM -
WANTED: SIEG C3 Mini Lathe
By derekm in forum Items WantedReplies: 5Last Post: 07-04-2010, 08:35 PM
