Thread: Spindle motor
    I am new to CNC (wood) and have recently built an OpenBuild C-Beam machine.
    The C-Beam uses a Dewalt 26200 router, this Dewalt router is exceptionally loud, with an ear piercing sound.
    Looking for advice on a quieter motor that can replace the Dewalt.
    Tony
    Quote Originally Posted by Lodds View Post
    Tony
    This sort of spindle is used a lot on here: https://www.ebay.co.uk/i/18180651404...7250873&crdt=0 They are very quiet and are available in different power versions.
    Thanks Clive,
    Did see those but the water-cooling turned me off. don't see how I could accommodate all the pipework water butt and pump within my limited space.
    Any thoughts on this.
    https://www.amazon.co.uk/dp/B019RA6S...detail_5?psc=1
    Seems to be the same sort of thing but without the water. It doesn't have the speed regulator which is a shame.
    Lives in East Lothian, United Kingdom. Last Activity: 2 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    I'd be dubious about air being enough to cool that style of spindle.
    The problem with air cooling, is it's the air cooling that makes most of the noise. If you get watercooled, then they are far quieter, and you don't actually need that big a water cooling system. Using a big bucket of water is an easy option, but you could create a far more compact system using a small cooler.
    Yes I have heard they are quieter. think it will be the water cooled option I might go for. I have seen that some people use a PC cooling system as opposed to long pipe lengths and water butts or buckets.
    Are the inverters difficult to wire, i have heard that they come with little or no documentation?
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 23 Hours Ago Has a total post count of 302. Received thanks 30 times, giving thanks to others 13 times.
    Thanks Clive,
    You don't need much space, all you need is a small pond pump, a small computer radiator, and away you go, best thing is it's so quite you could take a phone call at the same time you are cutting.
    Plus it don't wake the wife.
    Phill
    Phill
    Sounds so good Phill. As I said the Dewalt screams, even with ear protectors on it is unbearable. I have to do something about it.
    If you are using a pond pump I assume you would have a bucket of water somewhere? I would be interested in know what PC Rad you are using with a pond pump. I'm having difficulty reconciling the size of the pond pump outlets to the inlets of a PC Rad.
    phill05's Avatar
    No bucket you have a small tank on the pump and the rad it's a sealed system, my 3kw spindle never gets warm.
    I'll have a look where I got mine and get back to you.
    As regards the " inverters difficult to wire" the manuals take some understanding but you can always ask on here if your not sure.
    Phill
  10. The Following User Says Thank You to phill05 For This Useful Post:
  11. #10
    phill05's Avatar
  12. The Following User Says Thank You to phill05 For This Useful Post:
  1. Conect 121 DC spindle motor help!
    By Sooty in forum Spindles & Drive Motors
    Last Post: 05-02-2015, 03:31 PM
  2. Replies: 2
  3. Spindle Motor
    By pdl in forum Stepper & Servo Motors
    Last Post: 09-08-2011, 10:56 AM
  4. Spindle motor problems
    By geoffby in forum Motor Drivers & Controllers
    Last Post: 07-11-2010, 08:25 PM
  5. servo motor as spindle motor
    By Scott in forum General Discussion
    Last Post: 03-10-2010, 06:42 PM
