Thread: Spindle motor
    Cheers mate!
    Standard clear tubing? Pp or pe maybe?
    Standard clear tubing. The cheapest. No problem after a couple of years. And i really like using Pink liquid, so i see what happens. On my second machine i overdid it and ordered PU tubing from china. But there was no actual need in fact. The only difference was that the clear tubing around me is strange 5, 7mm and all connectors are 6, 8, 10mm. So as i wanted to do it more professionally looking with quick connectors, that was the only reason to use PU tubing. It cost very cheap from China.
    By the way i use quick connectors on the spindle side too.
  2. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  3. #2
    Thank you!
    Im looking for quick connectors aswell but there seems to be some special threading in the spindle. Maybe m8x1.. have to buy a bolt and test before I order anything :)
    If going with pc cooling stuff there seems to be alot of parts using od/id 10/8 tubing.
    If getting quick connectors with the same size I dont have to worry about reducers.. ;)
  1. Conect 121 DC spindle motor help!
    By Sooty in forum Spindles & Drive Motors
    Last Post: 05-02-2015, 03:31 PM
  2. Replies: 2
  3. Spindle Motor
    By pdl in forum Stepper & Servo Motors
    Last Post: 09-08-2011, 10:56 AM
  4. Spindle motor problems
    By geoffby in forum Motor Drivers & Controllers
    Last Post: 07-11-2010, 08:25 PM
  5. servo motor as spindle motor
    By Scott in forum General Discussion
    Last Post: 03-10-2010, 06:42 PM
