    Chaz's Avatar
    Start with similar speeds to Alu and go from there. With 2k rpm you will be very limited. With 16mm Id start around 500mm / min for a 10mm deep 1mm wide cut. Clear chips with air, delrin isnt difficult from what I recall.
    Yeah, pretty much what Chaz has said, I also have a 2000rpm spindle and usually cut delrin using cutters from 4mm up to 12 mm. I normally cut around 6mm depth @ 600mm/min. I never use coolant, or air blast for that matter, if needed I just follow the cutter around with the nozzle from the hoover
  3. The Following User Says Thank You to needleworks For This Useful Post:
    Air blast is better for getting chips out of slots and producing neater cuts, single flute end mills are fantastic in plastic where a deep slot is required.
  5. #4
    Thanks guys, I'll give it a try at the speeds you've said and see what results I get.
  1. Milling Plastazote LD33 closed cell Foam - Any milling advice?
    By Zeeflyboy in forum General Discussion
    Last Post: 06-04-2022, 10:12 PM
  2. Milling aluminium advice needed
    By zxrjohn14 in forum General Discussion
    Last Post: 08-11-2017, 02:18 PM
  3. Advice needed on everything
    By chrisjames in forum General Discussion
    Last Post: 11-11-2015, 11:40 PM
  4. VMC Tooling Advice Needed!
    By cncJim in forum Milling Machines, Builds & Conversions
    Last Post: 03-09-2014, 09:17 AM
  5. First steps, advice needed
    By Wobblycogs in forum Gantry/Router Machines & Building
    Last Post: 02-11-2012, 02:30 PM
