Thread: Bottom Chamfer in BOBcad-CAM V25
22-12-2017 #1
In our attempt to make this version of BOBcad-CAM work we have run into an issue. We need to chamfer the bottom side of a through hole in BOBcad-CAM. Most of our drawings are done through 2D in the program and we need to know a couple things on this.
1. How do you program a bottom chamfer tool using a Multi-Master top and bottom chamfer tool in BobCAD V25? Tool information at http://www.iscar.com/eCatalog/item.a...app=0&GFSTYP=M
2.Is there a way to program bottom chamfers into through holes using 2D drawings or would we need to use solid images to achieve this?
23-12-2017 #2
You are asking V25 to do something not supported at it's release but it should be possible.
You can do it with 2D geometry with a little ingenuity, I use a thread milling operation with one turn and near-zero pitch to generate code to cut a groove at the bottom of a blind hole, this gives you the lead-in and lead-out to get in and out of the hole clearing the cutter, you can edit the Z move round the one turn out manually fairly easily if you need to.
If you need more help you can give me a file to put an example into for you,
Regards,
NickLast edited by magicniner; 23-12-2017 at 11:11 AM.
Is having a wobbly bottom normal? Drill Vice...
By Dangle_kt in forum Workshop & EquipmentReplies: 9Last Post: 13-01-2017, 04:39 PM -
BUILD LOG: Worlds Greenest Stool Bottom CNC
By magicniner in forum DIY Router Build LogsReplies: 17Last Post: 24-03-2016, 02:27 PM -
v bit flat bottom
By universally in forum Tool & Tooling TechnologyReplies: 4Last Post: 01-10-2015, 10:25 PM -
CAD or Solidworks drawing to Bobcad / Bobcad full version v solidworks plug in
By suesi34e in forum BobCAD-CAMReplies: 2Last Post: 07-12-2013, 04:13 PM -
Chamfer Feed & Speed - G-Wizard?
By Tenson in forum Computer SoftwareReplies: 4Last Post: 05-02-2013, 07:01 PM
