    Good to see you are getting some time at least and some real life creations Andy! I think I need to use mine for every birthday/xmas present for the next 10 years to recoup the cost:)
    What method did you use to tram the spindle?
    Interested in the coolant mister too for the future - don't think I saw that in your build log?
    Ryan
    Quote Originally Posted by CNCRY View Post
    Ryan
    Haha - yeah. I've already gotten a couple of those ticked off...!
    The mister is a £5 jobbie off ebay - nothing special to it, just the generic Chinese one you'll find. Voicecoil has made me a new nozzle for it to open up the flow - he discussed the modification in one of his threads; I'll post a picture when I next use it.
    Spindle tramming - I used a dial gauge in the spindle, rotating it around on a surface place that is already setup to be planar to the Y and X axis. I have a tramming gauge which I would have preferred to use, but its with the mill locked down a few hundred miles up north.
    I love some of the designs on that site, especially the ones that use the wood as a spring to snap pieces together. They do test the accuracy of your machine though, I copied one idea which made a joint that had the pieces fit rather like the pieces of a jigsaw. Except they didn't. That was the inspiration for the latest round of upgrades which I'm hoping will significantly improve the accuracy of my machine. The Z axis is now made of aluminium instead of plywood so I'm cautiously optimistic!
    I consider wooden clocks to be a form of 'kinetic sculpture' just like Mr Roy's creations. Problem is I (unlike everyone else it seems) insist that a clock, any clock, should tell the right time. Hence my current (stalled for want of a working router) project for a GPS-locked wooden pendulum clock.
    Haha - I set the router up for a 16mm diameter hole, along with a series of already prepared GCode files for +/- 0.1mm offsets to try and fit the first bearing in. I can't tell you how happy I was when the 0 offset file measured 16.00 on the digital calipers, and the bearing was a tight push fit first time. Bliss.
    I suspect I'll end up trying to make a few of his designs... they're definitely in the amazing artwork category. GPS locking them however - that's another level!
    Couple more projects - My Brother wanted a 'Plumshed' sign (don't ask - long story), so I did a V Carve with some google fonts. Really love how much the black paint adds.
    Also spent some time trying to improve my 3D CAD skills - mocked up a Sopwith Camel prop, and tried a 3D carve. The router did an amazing job (its about 600mm wide) - I really love how smooth and flowing the contour is after a single finishing pass with a 6mm ballnose. The only issue I had was that I messed up the CAM and only got half the model (oops). Before this cut I was slightly worried about if my Z axis was okay - one of the earlier 3D carves had some suspected lost steps - but it handled this one perfectly. Cooling is definitely a need-to-fix item on my agenda though - that little pump just can't cope with the length of cooling loop I've got, and after about an hour the lower section of the spindle was hot (still comfortable to touch, but I'm guessing it shouldn't build up heat if the cooling is working well).
  2. BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
    By GeorgeW21 in forum DIY Router Build Logs
    Last Post: 20-01-2019, 09:33 AM
  3. BUILD LOG: Ar last!!! Started my Gantry 3-Axis CNC Build
    By MikeyC38 in forum DIY Router Build Logs
    Last Post: 16-06-2018, 11:29 PM
  4. Any sugestions how to build my gantry
    By masinecc in forum Gantry/Router Machines & Building
    Last Post: 20-09-2015, 05:17 PM
