    Y and X axis moving, apologies for the poor videography and mouth breathing; there are still no limit switches so I was trying to manually control and stay near the estop whilst filming, took far too much concentration.
    The Y is substantially quieter (smaller single screw and better alignment I guess) and here its setup for 10m/min and 500mm/s^2.
    The X still needs some alignment attention, here its running at 8m/min and 500mm/s^2. I think it was slightly crooked because at 10m/min something mechanical was slipping causing it to stall. Once a pulley was tightened and the gantry realigned it seems okay at 10m/min but time shall tell.
    It's sounding and seeming okay to me, but I have very little experience to compare against, so comments and concerns appreciated.
    Here's a short clip of the slipping I was seeing, after tightening the pulley grubscrew but before realignment:
    Hi Andy, Well done mate it's coming along nicely. Have you checked the steps per is correct because It doesn't look like it's traveling 8 or 10mtr/min to me, thou it's hard to tell from a video? Just use MDI and tell it to move a distance and check it moved the commanded distance. ie: G0 X100 it should move 100mm. Make sure you Zero the axis first and leave enough space to travel.
  2. BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
    By GeorgeW21 in forum DIY Router Build Logs
    Last Post: 20-01-2019, 09:33 AM
  3. BUILD LOG: Ar last!!! Started my Gantry 3-Axis CNC Build
    By MikeyC38 in forum DIY Router Build Logs
    Last Post: 16-06-2018, 11:29 PM
  4. Any sugestions how to build my gantry
    By masinecc in forum Gantry/Router Machines & Building
    Last Post: 20-09-2015, 05:17 PM
