    Quick update to the Aluminium Bead Presses. Other half demanded six sizes of the 3D hearts in both a horizontal and vertical press. Settled on a 0.2mm step-over - we did some tests lower down but whilst the finish was buttery smooth the tooling marks arn't translating into the glass, so decided this was a good compromise (or if they are, they're soon rounded up by heat). Getting some great consistency out of the presses, so happy customer :)
ID:	29030 Click image for larger version.
ID:	29029 Click image for larger version.
    We're now exploring other shapes.... (The ribs are intentional - not poor machining!)
    The machine is doing fantastically. Its been running 9 months now and hasn't skipped a beat. I had my first acrylic cutting experience recently which went very well. We used two layers to create an illuminated panel, solid grey on top cutting down through to a transparent opal - and if it wasn't a sign for my own address I'd be sharing pictures!
    My 4th Axis dreams are on hold for the time being however - a Warco metalworking lathe has just arrived in the garage, which changes things slightly, and I now need to learn how to turn. Never a quiet moment!
  2. The Following 2 Users Say Thank You to AndyUK For This Useful Post:
  2. BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
    By GeorgeW21 in forum DIY Router Build Logs
    Last Post: 20-01-2019, 09:33 AM
  3. BUILD LOG: Ar last!!! Started my Gantry 3-Axis CNC Build
    By MikeyC38 in forum DIY Router Build Logs
    Last Post: 16-06-2018, 11:29 PM
  4. Any sugestions how to build my gantry
    By masinecc in forum Gantry/Router Machines & Building
    Last Post: 20-09-2015, 05:17 PM
