Thread: AndyUK's Build - 1.2x1.0m Gantry
08-11-2020 #171
08-11-2020 #172
Ah, that's the problem with my machine! I never was very good at art. I only show my router to visitors wearing blindfolds, and who promise not to laugh...
08-11-2020 #173
X-Axis (dual, longest dimension, probably should be referred to as Y but I've long ago given up with that), ~280mm between the near edge of the first carriage to the far edge of the second (i.e the maximum possible dimension!). That was designed so that the spindle fell between the two.
Y-Axis (along the gantry) ~ 170mm. This mostly came out of wanting a 15cm wide Z axis plate and then having 1cm side plates.
Z-Axis ~205mm. This coincides with the height of the aluminium gantry profile, and the Y rails and carriages. The bottom one is placed as low as it can be without blocking the bolts on the lower Y carriage assembly plate, the top one is placed as far up before fouling the bolts on the upper one.
Totally appreciate the work area concern. Its one of the things that slightly frustrates me with this design is the work area is substantially smaller than the footprint - but hey. I'd recommend extending the rails at one (or both) ends if you can - If you extend rearward you can cut on the entirety of the bed, a slight forward extension would allow vertical clamping and working.
09-11-2020 #174An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
03-01-2021 #175
Christmas Gift:
(Plans from)
https://wilkerdos.com/product/rocker-templates/
The Following User Says Thank You to AndyUK For This Useful Post:
03-01-2021 #176
Nice!
04-01-2021 #177An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
04-01-2021 #178
11-01-2021 #179
21-03-2021 #180
Hi Andy,
I'm converting an X3 mill to CNC and after reading your build log amongst others I've been 'borrowing' heavily from your router electronics and circuit design. Could you tell me what software you used to create your circuit diagram please? Also, I saw your capacitor holders and noted that you printed yours after buying the wrong ones - inspired me to get a 3d printer, they were my first job. Just made protective caps for the top too.
I'll put photos of the bits I've made for the mill over on my build log when I've got a little further.
many thanks and stay safe
Geoff
BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
By GeorgeW21 in forum DIY Router Build LogsReplies: 14Last Post: 20-01-2019, 09:33 AM -
BUILD LOG: Ar last!!! Started my Gantry 3-Axis CNC Build
By MikeyC38 in forum DIY Router Build LogsReplies: 74Last Post: 16-06-2018, 11:29 PM -
Any sugestions how to build my gantry
By masinecc in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 20-09-2015, 05:17 PM -
BUILD LOG: Flying Gantry Build Diary
By geoff.sim in forum DIY Router Build LogsReplies: 8Last Post: 29-05-2008, 02:53 AM
