Thread: where to buy stock aluminium
23-12-2017 #2
It will depend how much you buy, what dimensions do you seek?
25-12-2017 #3
25-12-2017 #4
My non-ferrous suppliers are industrial and most of what I order is full 3m or 5m lengths of bar stock or 4' x 8' sheets of sheet/plate, they will get 1/2 or 1/4 sheets of plate or sheet in to order for me but they don't do it for walk ins/non-repeat customers, it sounds like you need somewhere that does off-cuts.
If you were closer I could probably sort you out from my personal stock but the drive would probably make it uneconomical and I don't post anything I haven't worked on,
Regards,
NickYou think that's too expensive? You're not a Model Engineer are you? :D
25-12-2017 #5
That sounds like offcuts for most suppliers. I have a small non-ferrous metal supplier near me that has as offcuts box - might be worth finding someone local and just dropping in, if you're not too fussy about sizes?
25-12-2017 #6
Have you tried :- https://www.aluminiumwarehouse.co.uk/
27-12-2017 #7
You're not going to get a Test Certificate for an offcut from a scrap bin - so unless you are confident about what you are getting then it may be better to buy something with provenance.
If you're going to machine it and not work it further then most of the Aluminium in the UK will do. If you are planning to weld it or anodise it then 6082T6 will be, most likely, what you will find most easily in the UK - and you should get plate or rectangular bar to fit your sizes. The 2000 series does not like being welded or anodised - I'm thinking 2024 or 2017 (Ok I read MEW too) - but it is stronger.
For the thin stuff perhaps someone may have an offcut or scrap plate of MIC 6 Cast Tooling plate - a lot gets sent back to the suppliers for scratches. It won't weld, it doesn't anodise - but it's ground flat and looks pretty, hence its use in small scale tooling projects. Other trade names apply.
When I go skip diving I know what's in the bins, and therefore what I'm getting. I'd hate to be in the position of having to make a load sensitive part like a footrest and not knowing what the material was.
Aluminium stock (billet/plate)
By Dangle_kt in forum Marketplace DiscussionReplies: 8Last Post: 31-12-2016, 07:44 PM -
Is there any such thing as a stock shaft material?
By gavztheouch in forum Metalwork DiscussionReplies: 7Last Post: 31-01-2016, 11:35 AM -
Metal Stock Purchasing UK
By paul_m in forum Metalwork DiscussionReplies: 7Last Post: 25-05-2015, 04:42 PM -
RFQ: RFQ: Keyslot milling in alu round stock.
By Saracen in forum Projects, Jobs & RequestsReplies: 2Last Post: 05-09-2013, 09:42 AM -
Method for holding Stock
By Chaz in forum Machine DiscussionReplies: 4Last Post: 24-06-2013, 11:41 AM
