Thread: Just blown up my inverter
24-12-2017 #11That sounds good and correct."No I never used an earth, the plug has 4 connectors and one of them is left empty (No 4) "
Pin 1 Phase 1
Pin 2 Phase 2
Pin 3 Phase 3
Pin 4 Not Connected
The spindle needs checking out as cropwell explained.
Regarding parameters I would change these.(when you get the new vfd)
PD014 acceleration time, 1 second is too short in my view, 5 seconds sounds better especially in the early stages of setting up.
PD015 decceleration time, same as above set to 5
PD142 motor rated current, set this to current specified for the spindle, I looked at some and the correct figure seems to be 8.5
PD143 motor poles, I don't know myself how many poles these spindles have but if people are using a value of 2 then it seems reasonable.
PD001 set this to 0 if you are using the keypad controls.
I'm wondering if you have reversed the motor several times without realising it from the front panel buttons, with ramp times of 1 second this may have caused some damage.
As you say, a short at the spindle end would not do the vfd much good.Last edited by EddyCurrent; 24-12-2017 at 03:26 PM.
The Following User Says Thank You to EddyCurrent For This Useful Post:
24-12-2017 #12
Also check this;
PD026 stopping mode, it should be set to 0 (decceleration stop)
Just to help things along in future, I would always let the spindle come to a standstill before pressing RUN again.Last edited by EddyCurrent; 24-12-2017 at 03:45 PM.
25-12-2017 #14
Don't mess with it, return it as faulty!
A decent VFD will detect an incorrect load, be it short or one or more disconnected phase (some detect open circuit but not all) and simply refuse to drive it with an appropriate error code rather than emit Magic Smoke!.
You shouldn't be able to bugger a VFD even by shorting the output, it should detect current overload, shut down and give you a meaningful error.
It's a bad 'un, send it back and buy something decent!
Regards,
NickYou think that's too expensive? You're not a Model Engineer are you? :D
25-12-2017 #15
To be honest I think it was a bit of both. I have placed an order for a new VFD and spindle, and have ordered 2 additional plugs so I can get the soldering right on my next attempt.
You guys are the best, thanks for all your help and not being judgemental. Merry Christmas to you all.
29-12-2017 #16
Just wired up the new VFD and changed the programming as before.
When I press "Run|" the spindle turns for about 2sec then I get an E.ora message and the spindle stops, any ideas? Seems I have been here before.
29-12-2017 #18
Hi Clive,
Thanks for the response.
I'm using the new spindle.
I have now got it working without error. I changed back some of the settings I had changed earlier. now it runs full pelt without error.
Just to to understand now how to display RPM and how to drop the speed?
Tony
29-12-2017 #19
Oh Forgot, this is my kit
https://www.ebay.co.uk/itm/2-2KW-WAT...53.m2749.l2649
Tony
Tony Just because it is running at full pelt does not mean it is correct! So I would go through the setting carefully to make sure they are correct. It is impossible to help with the parameters without knowing what you have set them to.
You don't want a repeat of what happened before
How to connect 2.2KW Inverter VFD?
By Tenson in forum Spindles & Drive MotorsReplies: 20Last Post: 13-07-2020, 01:47 PM -
VFD Has defantly blown up now!
By charlieuk in forum General DiscussionReplies: 34Last Post: 30-08-2017, 02:45 PM -
2.2KW 3HP Inverter help
By adamh in forum Spindles & Drive MotorsReplies: 8Last Post: 31-07-2015, 09:21 AM -
WANTED: Electrical Box for inverter
By badgerman in forum Items WantedReplies: 1Last Post: 28-09-2013, 11:08 PM -
Teco inverter
By Ronaldo9 in forum Spindles & Drive MotorsReplies: 9Last Post: 20-01-2013, 01:42 PM
