Thread: Just blown up my inverter
01-01-2018 #1Ok fitting a pot is very simple See this post #1 http://www.mycncuk.com/threads/7388-...hlight=fittingMy current position is that I have the spindle up and running and fixed to 12000 RPM, seems this speed is okay for most cutters?
I now know how to change the speed by setting the Hz. I have seen that some of you have fitted a Pod. Think I'll steer away from that for the moment, else I know what my next post will be on here.
Re the speed fixed to 12K what hz does it show as you might not have the motor poles set right it is either two or four I think it is pd143 set it to two
also as Eddy has pointed out pd14 ad pd15 need to be set to about 5 secondsLast edited by Clive S; 01-01-2018 at 05:25 PM.
01-01-2018 #2
How to connect 2.2KW Inverter VFD?
By Tenson in forum Spindles & Drive MotorsReplies: 20Last Post: 13-07-2020, 01:47 PM -
VFD Has defantly blown up now!
By charlieuk in forum General DiscussionReplies: 34Last Post: 30-08-2017, 02:45 PM -
2.2KW 3HP Inverter help
By adamh in forum Spindles & Drive MotorsReplies: 8Last Post: 31-07-2015, 09:21 AM -
WANTED: Electrical Box for inverter
By badgerman in forum Items WantedReplies: 1Last Post: 28-09-2013, 11:08 PM -
Teco inverter
By Ronaldo9 in forum Spindles & Drive MotorsReplies: 9Last Post: 20-01-2013, 01:42 PM
