Thread: Just blown up my inverter
I managed to understand enough of the manual that I was able to correct the initial programming of my HY inverter so that it showed the correct speed. As delivered, it worked fine but the speed readout was half what it should have been (based on the frequency display). Eventually I changed the "motor poles" setting which seems to have absolutely no effect on motor or speed but does correct the internal frequency-to-speed calculation so that the display is correct.
I used to use the display all the time on my Mk1 router which used manual inverter control, but since I installed it on the Mk2 with Mach3 control I barely look at it. I glance occasionally, but only when I'm wondering what the error between Mach3 and the actual speed is. Generally it runs a few per cent faster than commanded, but given that there is a digital-to-analogue and analogue-to-digital conversion going on there, that's not at all bad. And if a few per cent faster is the difference between something working and something not working, then I'm too near the limit anyway
31-12-2017 #2
Neale, provided the vfd does not use a sensorless vector control algorithm I think you are correct in assuming that motor poles will affect the speed reading only.
Also we are still waiting for feedback from Lodds about his new parameter settings.Last edited by EddyCurrent; 31-12-2017 at 02:34 PM.
31-12-2017 #3
How to connect 2.2KW Inverter VFD?
By Tenson in forum Spindles & Drive MotorsReplies: 20Last Post: 13-07-2020, 01:47 PM -
VFD Has defantly blown up now!
By charlieuk in forum General DiscussionReplies: 34Last Post: 30-08-2017, 02:45 PM -
2.2KW 3HP Inverter help
By adamh in forum Spindles & Drive MotorsReplies: 8Last Post: 31-07-2015, 09:21 AM -
WANTED: Electrical Box for inverter
By badgerman in forum Items WantedReplies: 1Last Post: 28-09-2013, 11:08 PM -
Teco inverter
By Ronaldo9 in forum Spindles & Drive MotorsReplies: 9Last Post: 20-01-2013, 01:42 PM
