    Hi Reefy, I have been running with a demo of DeskProto today and it is producing a good Tap file but very large, so I have not got the tool-paths right yet some more testing required, I think it will do what you want and it's not too bad to learn.
    Download a copy put an STL into it and watch the video for the settings you need.
    Phill
    The use of STL models for CNC path creation could be part of your file size issue, the paths will be following the polygons which form the surface and there will be many of them ;-)
    Nick I don't want to high-jack Reefy's thread but looks like we are both thinking along the same lines here, what would you say would be the best format to use to produce either a hand or in my case a car if not an stl.
    Phill
    Phill
    Phill,
    You could process an stl to reduce the polygon count, meshes lend themselves well to complex shapes but if you have fine detail in a mesh model you have a huge number of small flat surface elements which will break CNC tool paths into hundreds of thousands of short straight moves.
    Ideally you should work in the native format of the CAD system you use, then your CAM can use curves, I use Bob-CAD/CAM V25 so anything I want to share is usually exported as both .step and .iges and the recipient uses which suits them best, I only use the stl format for exporting parts for 3D printing.
    Regards,
    Nick
    figured it out and now have the results i was after and feel comfortable with the software now so that's great but the problem i am having now is the total hours to complete 31 hours, the size is only 180mm in length and 51mm in height. It may have something to do with what you say about stl file but my model was done in 3ds max with turbosmooth so it has alot of polys
    Quote Originally Posted by reefy86 View Post
    What roughing cutter & path and finishing cutter & path are you using?
    here is both rough and finish settings
ID:	23491Click image for larger version.
    Why are you roughing with a ball nosed cutter?
  1. eBay: ISEL Flatcom 40 1200mm x 800mm and Rotary 4th axis
    By badgerman in forum Items On eBay UK
    Last Post: 07-02-2017, 01:37 PM
  2. 4 axis rotary
    By Blackrat in forum CAD & CAM Software
    Last Post: 06-09-2015, 09:17 AM
  3. looking for a 5 axis cnc for largescale foam carving
    By marbles in forum Marketplace Discussion
    Last Post: 18-08-2015, 06:02 PM
  4. CNC Engraving Rotational Rotary Axis
    By Fivetide in forum Machine Discussion
    Last Post: 31-07-2015, 10:34 AM
  5. Sturdy Rotary Axis for CNC table
    By Boyan Silyavski in forum Linear & Rotary Motion
    Last Post: 31-08-2014, 11:53 AM
