29-12-2017 #21
If your CAM doesn't do it then something which must be part of your workflow must change feed speed with RPM - for any given material/machine/cutter combination there will be a small range of Feed per Tooth values which will yield optimal finish, tool life and job time.
Use a Feeds & Speeds calculator to get a ball-park figure and refine that for your machine through trial and error, a job which runs with a given RPM and feed speed can be problematic at half the RPM, you will be asking your cutter, machine structure and work to deal with double the depth of cut per tooth with significantly increased forces on everything.
Even when you have 4th axis full rotary available it's common practice to rough out with an efficient cutter, a 3-axis tool path and indexed moves then semi-finish and finish with rotary because that's more efficient strategy for time and tooling costs.
HTH ;-)You think that's too expensive? You're not a Model Engineer are you? :D
29-12-2017 #22
Thank you, the more i play around with it the more i bring the total time down but i won't know for sure how well the detail and how smooth it is until i test on the machine.
eBay: ISEL Flatcom 40 1200mm x 800mm and Rotary 4th axis
By badgerman in forum Items On eBay UKReplies: 1Last Post: 07-02-2017, 01:37 PM -
4 axis rotary
By Blackrat in forum CAD & CAM SoftwareReplies: 3Last Post: 06-09-2015, 09:17 AM -
looking for a 5 axis cnc for largescale foam carving
By marbles in forum Marketplace DiscussionReplies: 2Last Post: 18-08-2015, 06:02 PM -
CNC Engraving Rotational Rotary Axis
By Fivetide in forum Machine DiscussionReplies: 4Last Post: 31-07-2015, 10:34 AM -
Sturdy Rotary Axis for CNC table
By Boyan Silyavski in forum Linear & Rotary MotionReplies: 7Last Post: 31-08-2014, 11:53 AM
